Speaker placement issue.
  • Ron526
    • Oct 2006
    • 54
    Just relocated to Trumbull CT.
    Have finished basement with built in TV area.
    There are three rows of shelves surrounding the tv area.
    Have B&W602s3 for fronts and a LCR60 center.
    How will sound be affected if 602s are on their side?
    Should tweeters be to the inside or outside?
    The center will have a piece of wood right in front of the tweeter if centered.
    I probably will remove it ( would prefer not to), but since the LCR60 is a 2.5 setup could I offset it so the wood blocks some of the woofer side or the mid side?
    I know I can experiment with various positions but am hoping
    that someone had a similiar situation and can offer some advice.
    Any input will be greatly appreciated.
    Does anyone know of any clubs or groups in this area?
    I am a senior, have entry level stuff but I enjoy the sounds and talking about audio equipment.
    Thanx again Ron526.
  • comeup
    • 356
    how about some pictures it would be easier to advise. The B&W 600 series are great sounding speakers for the money.
    Blake
    • gd
      • Jan 2003
      • 583
      I think you won't want to hear this, especially if you've built the cabinet yourself, but...
      If you are planning on placing speakers within your HT cabinet – don't.
      This is the single worst thing you can do... it will defeat almost any attempt for quality sound... free-standing speakers are meant to be just that, they need space around them to play against the room and perform properly... placing a box inside another box can never yield clean, accurate sonics.
      The biggest obstacle to good sound is home decor... they're like oil and water... giving preference to one always involves compromise to the other.
      If it's at all possible (and I understand that it may not be), try placing all three front speakers in front of the HT cabinet if only to test the difference.
      Good luck.
      greg (gd to you)
      Frank Zappa
      • csuzor
        602+601: 600/675? Lcr60/600?
        by csuzor
        I've finally decided to move to 5.1 instead of stereo hi-fi, so bought an AVR1804 (6x90W) and 602 fronts and 601 surrounds. I have a 6x5m room half open on 1 side, high ceiling, hard tiles. I listen to 90% music / 10% movies, at low levels (just enough to hear all the sounds). I have always been against...
        07 November 2004, 15:50 Sunday
      • rick c
        LCR60 or LCR600 with 603s3???
        by rick c
        Was wondering if any you 603s3 users are using the lcr60 as a center instead of the 600.The reason i ask this is that i will using my existing center for now and i may only be able to afford the lcr60.I would like to get the 600 but i wont be able to right now.If any of you are using the lcr60 how compatible...
        24 November 2004, 14:50 Wednesday
      • twest820
        Neo3 PDRW and Neo8 PDR radiating area orientation
        by twest820
        BG's whitepapers for these drivers mention PDR reducing the effective radiating area as frequency increases but don't specify how the area varies. The Neo3 PDR paper talks about the area narrowing to a slit which is apparently parallel to the long axis of the driver, suggesting the long axis should...
        14 December 2009, 01:05 Monday
      • dpc rep
        Possible cabinet finishes?
        by dpc rep
        I like the veneered speakers that have been posted on here, but I also like a nice polished black finish as well. I have a finishing background, so either is possible for me. I am kinda leaning towards black cabinets with a solid wood outer front baffle finished out nicely with the same gloss. However,...
        25 June 2010, 17:50 Friday
      • scruffy57
        Help placing speakers
        by scruffy57
        Hi everyone. I was hoping to get some help placing speakers in my awkward shaped living room. I just purchased a tx-sr607 receiver. I have pinnacle gold aero gels front speakers, pinnacle gold center channel, and pinnacle gold reference for surround. I cannot fit the reference in the living room. I...
        07 December 2009, 00:48 Monday
