DVD audio player preferences?
  • bob4mvg
    • 18
    I'm a little confused which setting to use in my DVD player audio preferences menu, I guess I just don't understand the difference.
    Feeding the Rotel RCD1050 DVD into a RSX1067, should 1050 prefs be set to Dolby Digital/PCM or Stream/PCM? The default setting is Stream/PCM, but I'm thinking, maybe that should be changed? Trying to figure it out by reading the manual doesn't seem to work for me.
    Thanks for help again, I learn so much from this forum!
    Bob
  • Sim reality
    • Aug 2005
    • 173
    I am guessing Stream/PCM includes the digital out for DTS track (or it would read Dolby Digital/DTS/PCM) and the Dolby Digital/PCM converts the DTS track to PCM.
    • saurabh
      Convert Stereo Soundtrack -> DTS 5.1
      by saurabh
      But first to check if your 5.1 works fine.....
      http://www.sr.se/multikanal/english/e_index.stm
      Download the last item called "Multichannelcheck" in either DD or DTS. It's in Swedish but that makes no difference, it will do the job.
      Then an additional...
      21 April 2005, 22:23 Thursday
    • bhuskins
      Interesting News from Dolby
      by bhuskins
      "More Compatibility Seen Between HD Discs, Existing Audio Systems
      By Joseph Palenchar -- TWICE, 9/26/2005
      NEW YORK — Many consumers who already own an A/V receiver or preamp processor will have more options than previously thought to reproduce the highest bandwidth...
      06 October 2005, 19:11 Thursday
      Which new HD audio format should you use?
      I thought I'd post this to help out those who have taken the plunge into HD-DVD and/or Blu-Ray, to understand the BASICS of the new HD audio formats that it includes.
      The question is, when I pop in a new HD-DVD or Blu-Ray, when I get to the main menu, I've got a choice of several different...
      14 May 2007, 03:06 Monday
    • ericst
      Can't get DTS on C1
      by ericst
      I just purchased a C1, and everything works fine except it does not pick up the DTS signal from my DVD player. I am playing a DTS movie set to DTS. The DVD player says it is outputing DTS 5.1. I have a 5.1 setup. There is just no sound. When I switch the DVD back to DD it works fine. The input...
      03 January 2010, 14:25 Sunday
    • kiwi2000
      PCM vs Bit stream input to 1069
      by kiwi2000
      I have connected a Panasonic blu ray player model 35 to my system consisting of a rotel 1069 a/v switcher HDMI equipped with version 1.1.
      The player is connnected via HDMI to enable me to recieve the most current surround formats from dolby and dts.
      By chance I changed the audio...
      08 December 2008, 17:48 Monday
