I have a NAD T751, C270, and T512 DVD. Just bought a SONY WX 700 sub (I know, but I got it reallly cheap) but I can't get any sound out of it in DTS mode. OK in DD, stereo etc. Any ideas? 8O
Sub problem with DTS
Are you getting a DTS signal out of your mains, center and surrounds?
Cicero, check your PMs..
Yes, DTS is fine through the ,mains, surrounds, centre...Can't figure out the lack of sub though. I think DTS sounds much better than DD, which is why I am freaking. What is a PM? Thanks for the help.Originally posted by David MeekAre you getting a DTS signal out of your mains, center and surrounds?
Cicero, check your PMs.- Bottom
A private message. Go to User CP and then select list messages.Originally posted by ciceroWhat is a PM?.
Back to the problem. Have you checked, in the receiver, the volume setting for your sub when using DTS? My Yamaha RX-V1 has separate volume settings for each sound format for the sub when using DD or DTS..
by fauzigaribHey all,
Here's a question that just hit me while I was considering room corrections in my brand spanking new HT.
Just FYI, I have the following system:
- Lexicon MC-8 Processor
- Kef Q7 Mains
- Kef iq6c center
- Surrounds Kef iQ3 and q2's....-
by Win1Hi all,
I have a pair of B&W CM10's running off a Nad C370 pre/power amp & a Nad C270 power amp both bridged rated 300Wrms each. The power amp section on both units is identical, the C370 just adds a pre amp.
My room is 32ft by 15ft.
I am pleased...-
Channel: Club B & W Speakers
by ajpoeHello all! It has been a while but I figured I'd come back to the experts. I've been enjoying my DIY subs since 2005. If you do not recall, here is my project:
http://www.htguide.com/forum/printth...4&pp=50&page=1
I can't even tell you how many times...-
Channel: Mission Possible DIY
by FoxmanHey guys I may or may not have an issue. I noticed when I watch regular satelite programing with DTS I have zero sub sounding bass. With dolby digital on the same station I do. I have watched movies with DTS and never noticed the lack of sub. When I select DTS I made sure it was cinema not music, although...-
Channel: Club Rotel
by LiciniusI was mulling over the idea of building http://zaphaudio.com/BAMTM.html for a friend who wants a fairly cheap pair of full-range speakers, stereo only. He doesn't want a separate sub, so I was considering building these sealed in a tower with 1cf for the MTM and 1-1.5 or so for a sub (ok, so maybe...-
- Loading...
- No more items.
