Signal flow.. Does it have any influence ??
  • Gadgets
    • Dec 2003
    • 19
    Does the Signal flow arrow noted on audio interconnects has any influence ? can someone explain ?
    Thanks !
    • 10931
    The majority of the time it simply indicates the direction the wire is 'drawn' (pulled) through the forming die.
    Sometimes it referres to a scheme where there is a lifted ground (drain ) wire at one end of shielded IC. This is called a telescoping ground.
    In the case of the telescoping ground IC's yes pay attention to the arrows.
    If the arrows are just indicating a wire draw direction just listen and see if you prefer one direction over the other.
