If you have a 2-channel system with a subwoofer do you let your front speakers run full range (even though they arn't large speakers) and then calibrate the sub to the rolloff? Or, if you have a separate Pre/Pro do you wire it through the subwoofer (4 rca-connections) so you can use the crossover to cutoff the front speakers also? I am trying to understand what most 2-channel people recommend.
2-channel system with subwoofer calibration & connection.
?? Neither. If you have a prepro, you let the prepro do the crossover for the main and sub and you use the EQ in the prepro or the sub, depending on what you have. If you do not have a prepro, then you use use the crossover and EQ in the sub. Alternatively, you get an external box, like the Velodyne SMS-1, to do both.
KalKal Rubinson
"Music in the Round"
http://forum.stereophile.com/category/music-round- Bottom
I am in the early stages of my stereo system. I finished a pair of mains late last year. Finished a pair of subs early this year and have been fiddling with integration for a while now. I have built and been involved in integration of subs in other peoples stereos before and I have found that on my system using some sort of active crossover to roll the mains off where the sub starts seems to be a better way to go all around. It uses the separate channel amplifiers more efficiently and so far, at least in my case, just sounds alot better together.
I personally am using a PC with an Audigy ZS2 and special drivers to handle the frequency splitting, time alignment, phasing and parametric eq for the sub. It sends the signal to a Parasound amp for the subs and an Arcam amp for the mains. It may not be the best solution but for someone with expensive tastes on a shoestring budget it was a great zero dollar solution for me.- Bottom
Isaac, I'm a 2-channel bloke and I use the crossover in my sub as Kal has suggested.
My floorstanders receive 80 Hz and above. Theoretically I should therefore set my sub to play 80 Hz and below. However I have found that varying this setting between 80 Hz and 120 Hz provides beneficial results, particularly for music DVDs. It really depends on the recording that you are listening to. In theory you shouldn't have the low frequencies coming from your sub and your speakers. It is frowned upon. However I suggest that you experiment and find out for yourself.
Nigel.- Bottom
Originally posted by Kal Rubinson?? Neither. If you have a prepro, you let the prepro do the crossover for the main and sub and you use the EQ in the prepro or the sub, depending on what you have. If you do not have a prepro, then you use use the crossover and EQ in the sub. Alternatively, you get an external box, like the Velodyne SMS-1, to do both.
Kal
So Kal on an other subject do you care to comment on Dave Nauber at Classé. "Automated EQ is rubish, and our SSP-800 is world leader"Farming looks mighty easy when your plow is a pencil, and you're a thousand miles from the corn field."Dwight D. Eisenhower- Bottom
Thanks for everyone’s input. I currently use a rotel RSX-1056 with B&W 805s and ASW825 subwoofer. Used to be more into HT but slowly converting to 2-channel. I would like an integrated amp (Classe or Mcintosh) because of convenience but not sure how to integrate the subwoofer in the mix because the asw825 is not really designed for an integrated amp. For separates most subwoofer instruction manuals show the subwoofer connected PRE>SUBWOOFER>AMP but, unless the subwoofer is located right next to the equipment wiring could get pretty hairy (expensive and long interconnects). I am pretty happy with the sound I have now but, I am one of the many people who probably are under powering my 805s's and want to give my 805s's the power they deserve.- Bottom
Originally posted by wettouWhat about the JL Audio Fathom F113 do you still do calibration in the pre/pro?
So Kal on an other subject do you care to comment on Dave Nauber at Classé. "Automated EQ is rubish, and our SSP-800 is world leader"Kal Rubinson
Originally posted by bigburnerMy floorstanders receive 80 Hz and above. Theoretically I should therefore set my sub to play 80 Hz and below. However I have found that varying this setting between 80 Hz and 120 Hz provides beneficial results
I for one find it best to integrate the sub at the point where your main L / R speakers bottom starts to 'roll off' and do so with a fairly steep slope so as to allow the sub to get out of the way without any coloration into the midbass region.[/Quote]
In theory you shouldn't have the low frequencies coming from your sub and your speakers. It is frowned upon. Nigel.
the real problem come from having the sub operate beyond the 80-100hz range, it is a 'sub' afterall, not a Upper Bass driver !Dave- Bottom
Originally posted by twitch54the real problem come from having the sub operate beyond the 80-100hz range, it is a 'sub' afterall, not a Upper Bass driver !
"A mind is like a parachute. It doesn't work if it is not open."
— Frank Zappa
I just experimented a bit and that's what I discovered.
Nigel.- Bottom
Originally posted by IsaacThanks for everyone’s input. I currently use a rotel RSX-1056 with B&W 805s and ASW825 subwoofer. Used to be more into HT but slowly converting to 2-channel. I would like an integrated amp (Classe or Mcintosh) because of convenience but not sure how to integrate the subwoofer in the mix because the asw825 is not really designed for an integrated amp. For separates most subwoofer instruction manuals show the subwoofer connected PRE>SUBWOOFER>AMP but, unless the subwoofer is located right next to the equipment wiring could get pretty hairy (expensive and long interconnects). I am pretty happy with the sound I have now but, I am one of the many people who probably are under powering my 805s's and want to give my 805s's the power they deserve.- Bottom
Nigel,
No problem, whatever makes your ears happy with your system is all that matters !
I was just mearly stating that I know of no sub that is designed to work beyond the second octave, at least in a 'accurate musical' enviroment.Dave- Bottom
I followed conventional wisdom for about 18 months until I received a PM from a fellow HTG member (who shall remain nameless) who suggested that I experiment a bit. I did and I've never looked back.
It could just be a peculiarity of my system.
I'm writing this while watching a Wilco DVD and it sounds fantastic...
Nigel.- Bottom
