Using bi-wired cable on not bi-wired speakers
  • Steve_R
    • Mar 2008
    Is it possible? I like to hear your opinions!
    Thanx in advance.
    Steve
  • whoaru99
    • 639
    Thanx in advance.
    Steve
    Sure, you could, but not sure why you would - unless you have some laying around that need to be used.
    ----JAFFE'S PRECEPT
    • caned_monkey
      Laying Speaker Cable Correctly
      by caned_monkey
      Hello there!
      I am currently setting up a home cinema/hi-fi system in my living room and i am up to the stage where i'm about to lay the speaker cable(about 25m), all of which will be hidden inside pvc trunking. I have a couple of questions, if any of you audiophiles out there can help...
      10 March 2009, 07:53 Tuesday
    • shep
      Bi-wiring 804s worth it on long cable runs?
      by shep
      I'll try to keep this one within the bounds of the B&W page, but can already guess it might be best answered elsewhere. Need some advice. Leaving cable brands aside, lets say I have store-bought 12 gauge cable (CL rated for in-wall), running 50 feet from my stereo/HT setup in the family room (amplifier...
      05 February 2005, 11:09 Saturday
    • qtybry
      speaker cable for cm9
      by qtybry
      hello guys,
      what speaker cable can you recommend for my new cm9 for audio listening only?
      my new set up is rotel rb1572, rc1550, rcd1520. thanx
      10 August 2010, 13:09 Tuesday
    • qtybry
      audio cable for rotel with b&w
      by qtybry
      hello guys,
      what audio cable can you recommend for my new set up rotel rb1572, rc1550, rcd1520 and speakers b&w cm9? thanx
      10 August 2010, 13:17 Tuesday
    • BW4me
      Cable recommendation
      by BW4me
      I have a Dell 3300 projector which is HD compatible up to 720p or 1080i using it's M1-DA connection. After trying to find BD player that upscales DVDs using component output (which is my current set up - M1-DA to component cable) I just realized I should just get a HDMI cable to replace current cable...
      18 August 2009, 15:55 Tuesday
