Cable recommendation
  • BW4me
    • 75
    I have a Dell 3300 projector which is HD compatible up to 720p or 1080i using it's M1-DA connection. After trying to find BD player that upscales DVDs using component output (which is my current set up - M1-DA to component cable) I just realized I should just get a HDMI cable to replace current cable and use with HDMI to M1-DA adapter.
    So my question is, what type of HDMI cable can I run about 40' up through wall and into attic to projector? My current cable is from Dell, which works great, but they don't sell anything like I need in HDMI.
    Then, I'm assuming I could get some type of HDMI switch box to run two into one on player?
    Thanks for any ideas,
    Steve
  • George Bellefontaine
    • Jan 2001
    • 7636
    HDMI cables are so finicky I am hesitant to make recommendations, especially when it comes to something like a 40 foot run. With HDMI, I have found that they either work or they don't. I have two projectors in my system, as well as two Blu-ray players with each connected to a projector by 22 foot flat HDMI cables, 26AWG and manufactured by Atlona and sold for roughly $80 a piece. All I can say is these work for me when a cheaper make didn't. In your case, especially considering you will be running the cable up a wall into the attic, as well as through an adapter, I would only buy from some local dealer who will offer some kind of a guarantee should the cable not work.
    My Homepage!
    • BW4me
      • 75
      Thanks George. This was one of the cables I was looking at from Monoprice.
      http://www.monoprice.com/products/pr...seq=1&format=2
      Currently I've been using an in-wall rated 50' Dell component cable which has given really good results. It was only $50, but maybe from what you're saying it's a whole different situation with HDMI.
        • Jan 2001
        • 7636
        Component cables have always been pretty reliable, but HDMI cables are much more complicated and often finicky.
        As far as Monoprice cables go, I understand that many people have had good results with them, but again I would only buy if you can return them for a refund if they don't work.
        Good luck.
        My Homepage!
        • John Holmes
          • 2707
          I have a 35' HDMI from Monoprice. I have it connected to my 720p projector. Around 2 yrs now, no problems.
          • BW4me
            • 75
            Thanks George. I'm also going to make sure I check cable out before I run it through my wall, whatever I end up with.
            • aarsoe
              • 795
              There is another way to ensure pristine picture and sound - and that is to use a repeater after 20 feet. Not all repeaters require external power and it is much cheaper to get a real quality cable at 20 feet than 40 feet.
              • mwgwin
                Connecting PC through AV receiver (DVI/HDMI)
                by mwgwin
                Has anyone had trouble connecting their PC through their receiver?
                Here is my setup
                PC with ATI Radeon 9600 Pro video card with DVI and VGA outputs.
                Yamaha RX-V1600 with 2 HDMI inputs and 1 HDMI output
                Dell 5100MP projector with about one of each type of input imaginable....
                08 December 2005, 10:58 Thursday
              • Jeremy77
                50ft HDMI cable: which brands?
                by Jeremy77
                I am getting a Sanyo PLV-Z3 projector (HDMI input) and I am looking at getting a Oppo Digital OPDV971H dvd player (DVI-D output) and was wondering what brands are recommended for HDMI cables? (the distance from the projector to the dvd player will be about 45ft).
                So far the least $ I have found...
                16 May 2005, 01:01 Monday
              • Ovation
                Bought two HD DVDs and an HDMI cable, got a free HD DVD player
                by Ovation
                Title says it all. Couldn't resist the price (80$) for the A3. I was planning to get a regular DVD player soon (a bit of re-arranging of gear was going to leave an SDTV without a DVD player) but for the price, I got an SD player, a future HD player for the upgraded display (down the line), a back...
                27 February 2008, 09:37 Wednesday
              • rgabriel
                Long HDMI cable run.
                by rgabriel
                Hi Everyone this is my first post.
                I'm in the process of building a home theater setup in my basement downstairs. I want to wall mount my 42" lcd on the wall, I wanted to remote mount all of my equipment underneath my Bar and use ir blasters and a long hdmi cable. My question is,...
                26 August 2007, 12:06 Sunday
              • KRC
                directional HDMI cable
                by KRC
                As with alot of interconnects and speaker cables say they are directional (ie follow the arrows), would an HDMI cable also be directional.
                By adding one of those couplers to an HDMI cable (DVI to HDMI/HDMI), does it take away from the quality of the sound. I was told in the past that...
                01 January 2008, 16:26 Tuesday
