Hi again Steve,
Well I think I've got my feedback problem 90% licked. I got out my old isolation feet again. Put those under the turntable feet, this helped alot. Then I put a piece of drywall between the isolation feet and the turntable feet. That helped some more. Now using the needle on a stationary record test I do not get any feedback until I turn the volume knob to a point that would have my amp clipping like mad if music was actually playing. I think I'll make a thicker, heavier, intermediate shelf, and try to make it look pretty, then I think I'll be done - again.
I think you can bring over Dave Brubeck, Take Five, and hear it without feedback.
BTW if you buy that Music Hall MMF-9 and it doesn't solve your problems I'd be happy to trade you my table for it
I've reread this thread. I think you have four things working against you.
1) your turntable is close to the speakers.
2) your turntable is sitting on top of a tuner (seperated only by a thin piece of wood).
3) your turntable is sitting in a stand that sits on the floor (probably a wood floor
that vibrate like crazy.)
4) your turntable may not have good built in isolation.
I was thinking the other day that granite counter tops are very popular these days.
Then I noticed that my turntable would fit in the kitchen sink. I don't know what they do with sink cut outs, probably discard them.
I wonder if kitchen counter installers might be a good source for cheap heavy flat
rocks to go under a turntable.
Perhaps if instead of placing your turntable on top of your tuner, a thick heavy sturdy shelf would be more suitable. You could go one step further, first the sturdy shelf, then some absorbing feet (sorbothane?) then another piece of rock, then your turntable on top.
Actually drywall (gypsum board for the non-US folks) has some potential benefits. It is cheap (or free if you have a scrap in your basement like I did). It doesn't ring as much as rock. But rock looks so much nicer . . .
