I have an Adcom 200w 2 channel amp w/ Adcom preamp/tuner. Practically, can I create a surround system using this gear? Or, am I better off getting a good 5 channel receiver (Rotel) and save my heavy duty stuff for music listening only? Cost is indeed a factor.
Creating home theater with 2 channel gear
Tags: None
You could certainly connect a DVD player or cable box to your Adcom and have a "2 channel home theater", but to get surround sound and video switching you'll need to get a HT capable receiver or preamp and amps.
If cost is a factor, you could always start out with a "2 channel home theater" and then add a 5.1 or 7.1 capable receiver for HT down the road. And you can continue to use your existing setup for music.- Bottom
Keep your 2 ch gear and by a good AV receiver with main pre-outs and drive your main speakers via your pre/power Adcom. Connect your CD to your preamp, not to the AV receiver. Your AV receiver will just drive the surrounds, centre and sub.- Bottom
by DaymondHey, I'm new here and looking for some experienced advice from those who own one of, or compared the above. I've narrowed down my choices between these two, and can't decide which way to go. The goal is to replace my 5 year old Denon AVR-3300 receiver. The nod is going to the Adcom receiver as I have...-
29 April 2006, 21:58 Saturday -
Channel: Club Rotel
Integra Home Theater (not to be confused with Integra Research) :>) has announced the first separates with the Integra name.
Integra DTC 9.4 Pre/pro
http://www.integrahometheater.com/press.cfm?id=65
More details about the pre/pro:... -
by RolyasmMy father was using an Adcom GFA 7000. He wanted to connect a sixth speaker to the 5 channel amp and thought he would try some crafty wiring. He took the speaker cable from the sixth speaker and split it four ways, connecting a pair to both left surround and right surround channels (thinking he would...-
by ktaillonI have a two channel system using an Adcom preamp feeding a Adcom two channel amp. If I were to pickup a super audio capable dvd player could I use just two of the analog outputs for stereo play back? If I remember correctly Super audio outputs through a analog 6 channel out - NOT a digital out....-
Channel: Audio Hideout
- Loading...
- No more items.
