How does your room effect the sound of your speakers
  • nezz621
    • 21
    I've researching my Dayton TMWW, and people hve been saying how different rooms change the sound characteristics of speakers. I've heard that the TMWW need the right room in order to sound correctly.
    So my question is... How much will it matter if i dont have the right room?
    Currently im getting ready to move into an appartment so im not sure what my room will look like.
    It always matters.
    How close to walls is probably the biggest issue, which may alter how much baffle step compensation you really want to have. But too much can often be handled simply - say, turn down the bass on your receiver (assuming you have such capability in your system).
    Some things can be solved with simple room treatment, others with more involved room treatment.
    ALL speakers have the same issues (though different radiation patterns work differently - dipoles have different restrictions than monopoles, for example).
      The room makes a big difference. The best sounding orientation might not be what you'd envision. Room treatments can salvage a less than ideal space. Look into the threads on absorbers and diffusers.
      I have a space ~11x20 that opens up halfway along one wall to the dining area (typical joined living and dining room). The half wall opens up to the kitchen. When I initially set up with the speakers along the 11 foot wall I couldn't get decent sound without fairly significant treatments to absorb the first reflections.
      I turned the system 90 degrees so that the speaker closest to the corner is 4 feet from a side wall. This places my listening position close to a 2.5' wide section of wall. I treated it in much the same way as the "aeropanel" or something like that in a thread here - basically 4" of fairly tightly packed fiberglass in a grill cloth covered frame that covers the wall section behind me. With a passthrough to the kitchen on one side and open space on the other, I do OK.
      Imaging is MUCH better than before, as is detail, since it doesn't get muddied in early reflections. This arrangement also allowed me to put my subs in spots that help minimize room modes. Do I wish I had open space behind my listening position? Yes. Do I get very pleasing sound out of the current configuration? Yes again.
        • 16163
        Check out RPG Acoustics for some insight into this topic.
        • warnerwh
          • 261
          Also there's a wealth of info at www.realtraps.com including videos. We all are affected by our rooms. It can make a huge difference, more than changing speakers even.
          • auchain
            I even didn't konw the room change the sound so much. If the speakers didn't sound uncomfortable, then I wound not change the speakers' position.
            • sendler
              • 13
              Room treatment
              Room treatment is very important and one of the most cost effective upgrades you can make to your audio system. Carpeting or rugs are something that any "interior decorator" can be talked into. Speaker placement should be considered as they will sound much better if placed out from the front wall. My room is 16' by 14' by 8.5' and my tweeters are out 53" from the front wall on solid stands. If you can't leave them that far out into the room then place a small mark into the carpet with a piece of masking tape or something so that you can move them back into position for serious listening sessions. My listening position also places my ears out from the back wall 39". Again, you can move things into better position for listening if you can't leave them for the best sound all of the time. Move around and listen for the best sound. Wall treatments are more difficult to sell to the "decorator" but are crucial to the best sound. Heavy quilts don't cost that much and can be chosen to add to the decor. Heavy draperies work well also. The key places are in the corners behind the speakers and at the first reflection point of the sidewalls. I use a queen size quilt for each and one on the wall behind me. Sit in the listening position and have a helper hold a hand mirror against the walls in various places. Wherever you see the speakers in the mirror is a reflection point. It is possible to use too much absorption. I actually tried some absorption on the ceiling at the reflection point and covered up the video monitor which is between the speakers but removed it as it didn't improve the clarity at all and only served to rob some of the impact from the bass. For the final touch on absorption, treat all four corners of the ceiling with pieces of acoustic foam cut to fit about 18" of the xyz axis of the ceiling/walls. Your new room will sound much more detailed and quicker for music and even in conversation.
                Is it really so difficult to do this?
                • lbstyling
                  • 80
                  take a look at a behringer DEQ2496, there are many that swear by them. this is for stereo only though.
                  the eq'ing is done in the digital domain and the dac is jitter correcting. you can use your own dac if you like.- i understand it doesnt correct phase allignment. you need to pay a lot more for this.
                  • Kevin Haskins
                    • 226
                    Good question, go buy this book. I'm finishing it up now and it has been an excellent summary of the research. It won't answer all questions but it gives you pretty good hints into what is important about the room for both 2-channel and multichannel reproduction.
                    • TacoD
                      • 1080
                      http://www.amazon.com/Sound-Reproduc...1645196&sr=1-1
                      I second this recommendation, the book is relatively cheap too!
                      • goskers
                        • 106
                        I triple agree that everyone should get this read. In my opinion, this is the best book I have ever read on audio as a whole. A pretty easy read considering the topic.
                        • P-Dub
                          Calculating room volume?
                          by P-Dub
                          Well, in a nicely closed off room, that's easy, LxWxH. But what about the various opennings? At what point do you say, enough is enough?
                          Take for example a house I'm looking at renting. The main living room is nice and large, I'd estimate a 24ft x 18ft x 8ft room. But it's not closed...
                          14 June 2002, 15:32 Friday
                        • indiebands
                          Room acoustics and treatment options for 803D based system
                          by indiebands
                          We plan to move to a new house soon. It is a rental, so we have to live with the space pretty much as is. It is obviously not an optimal “listening room” but I wanted to ask what kinds of room treatments I should consider (there will be a carpet in the listening triangle).
                          My current...
                          12 May 2009, 04:08 Tuesday
                        • sombody_nobody
                          Great Media room-But 1 MAJOR issue to resolve!
                          by sombody_nobody
                          I was visiting this forum as an outsider and followed all the great info that gets passed around and was wondering if any of you experts can help me.I am building and buying a home for the first time, which is in its final phase and will be completed in the next month or so.
                          01 August 2014, 10:37 Friday
                        • sikoniko
                          New Theater Room Planning
                          by sikoniko
                          I have been inspired. I recently married my girlfriend of 5 years and bought a house. The home was a model, so the garage is insolated, as well as heat and cooled.
                          As soon as we get done working on the bathrooms, We will begin converting our garage into a theater room. It will have one...
                          18 December 2005, 08:25 Sunday
                        • EastCoaster
                          Room Treatment advice for my B&W and wooden floors?
                          by EastCoaster
                          Howdy all,
                          If you remember, I was planning on moving between apartments with my 4 x 805s, HTM4 and ASW 825. My old apartment had great acoustics - I felt like I was inside of a warm bubble of sound... My new apartment's acoustics are scary - horrible... Harsh and bright highs, boomy...
                          12 April 2006, 17:42 Wednesday
