NatP Journey Begins
    • 16171
    Thanks- glad you’re enjoying them. Your description of them mirrors the intent… with lower than typical distortion for a system of that size and cost.
    • mischmat
      • Feb 2010
      • 139
      So, a bit of time has gone by, things are broken in.
      Did some room corrections with the parametric on the amp.
      I must say these things sound amazing. I'm still dumbfounded as to how much bottom end they have, and they play loud effortlessly.
      John these deserve another thanks from another member of the DIY community.
        • 16171
        Thanks for the kind words, just glad that you enjoy them- I still haven't figured out a better moderate cost speaker. Still thinking about it from time to time, but those drivers are classics- and the crossover technology is basically the same as what I use in the Ardents and Isiris, but in a quasi-series/parallel arrangement that has a very easy impedance curve to drive, and deals with the specific issues of the RS180 with minimum number of components.
        • SE-Raider
          "Slot-loaded" sub designs?
          by SE-Raider
          I've seen several "slot loaded" subs lately, or at least designs described as slot loaded. An example is the 8-inch offering from av123. Many of these designs are down firing, and a partition is placed a few inches away from the face of the sub, loading the front wave; an opening around the...
          19 February 2006, 19:21 Sunday
        • Greenmeanie777
          Tuning Help
          by Greenmeanie777
          Curious if someone could figure what the tuning is of this enclosure. Cabinet has a net volume of 2.61297 ft^3, the port configuration is as follows: slot port 2.75"X5.825"X12.750", then 2.000" from back of slot wall there is a 4.000" dia.X12.000"...
          18 August 2011, 15:09 Thursday
        • crackyflipside
          Having trouble figuring out sub port length with enclosure constraints
          by crackyflipside
          I'm trying to design a dual ported sub into the base of an entertainment center. I modeled everything in WinISD, but when I reduce the enclosure volume by the port volume, the port length has to change to get the tuning, which changes the enclosure volume again. So I'm stuck in a cat and mouse trying...
          11 January 2021, 09:55 Monday
        • randyc1
          Slot port question ??
          by randyc1
          If I compare a 2" (Area of 3.14) ROUND PORT x 8" long . Then build a SLOT PORT of 3.14 "x 1" (same area as 2" round) .
          (...one of the 3.14" walls of slot allready exsists in speaker ,will build three others)
          Should the Slot Port...
          29 March 2013, 18:50 Friday
        • alteredbeast77
          slot vent length
          by alteredbeast77
          hello all
          need a little help with with vent length.
          single 15"driver
          enclosure is 48"w x 18"h x 24"d,all panels and port walls 1.5" thick throughout
          gross volume 8.2
          net volume 5.0
          tune 20Hz
          one chamber
          16 August 2011, 09:06 Tuesday
