Oh, ok. I was lookig at this pic: http://4.bp.blogspot.com/-G1ozDVnDNb...2Bsonogram.png
S14 - 4 Way OB using Seas and Vifa/Zaph drivers
Yes, that's the correct one for 'R16'. The previous one (smoother) was for 'S16'. It had much simpler baffle.- Bottom
Yes, XT25 are nice indeed. And super-flat when measured.
And nowadays cheaper too!!- Bottom
So years later, do you still feel the W-frame design reduces cabinet vibration enough to make separate upper-range driver baffle mounting as in the LX521 unnecessary?
PS -- any other speaker work lately, or is this really your final creation?!- Bottom
I agree with you completely on the H1212. Around 2.5Khz it is quite "shouty". didn't appear in low power distortion sweeps, but the shoutiness was volume irrelevant. I reverted to using the fabric dome which was better.
I was also pairing with an L15 which may have contributed as well (3rd order breakup around 2.7KHz so may not have been attenuated enough.- Bottom
by JonMarshI've spent too much time talking about the ZA14 in the Dayton Esoteric thread, which is not a good example for a moderator to set for staying on topic. To that end, I'm starting a new thread- it will include my own thoughts and observations, and I expect will eventually include some proposed and tested...-
Channel: Mission Possible DIY
by benchtesterJust a heads up. Zaph has a conceptual design challenge.
At least one pair of the ZA14's will be given as a prize.
http://www.zaphaudio.com/blog.html...-
by Dean100Now that your ZA14 mid/woof has been out for awhile, I was just wondering if you have anything new in development that we may see soon?-
by ---k---Zaph recently posted a new 3.5 way design using the RS180, RS52 and an Aura NT1.
http://zaphaudio.com/ZDT3.html
Zaph said he was hesitant to post it because of so many existing RS designs (Like mine!
). I just want to say a public thank you to Zaph for posting it....
by lunchmoneySo after weeks of agonizing over what speakers to build, I finally decided to go smaller and higher-end, and build the Zaph SR71's...
First things first: huge thanks and round of applause to Zaph for his enormous contributions to the DIY community, including this design. I have spent many...-
Channel: Build stories
- Loading...
- No more items.
