Today my plan was to cover the front and sides of one of my Statements with a monstrous 4' x 5' sheet of veneer. I really should have tried my first veneer job on some book shelf speakers! I was quite nervous.
There were a few blemishes on the veneer. I wanted to do a dry fit to align most of the bad spots either off the speaker, or in one of the driver cutouts. When I dry fit the veneer, I could hear some splitting as it curved loosely over the 3/4" radius of the baffle. I thought I was going to have a mess on my hands. I did some web-research on softening the veneer, but decided against it. It's paper-backed, so it shouldn't need it.
I coated the speaker cabinet and veneer with glue (a pretty thick coating, so my edges wouldn't come loose this time). I figured I might as well go through with it, and hope any splitting would be minimal. The glue on the veneer took 4 hours to fully dry (it was accelerated in the last hour by a halogen lamp warming it). I may have use a little too much glue!
I ironed the veneer onto the cabinet. No splitting. I waited 2 hours for the glue to cure, then I checked for loose edges. One TINY area. I was within the reactivation time of the glue, so I just gave it a little ironing.
I felt pretty intimidated by the huge sheet of veneer, and the possibility of splitting, but the process went really smoothly. I think the heat from the iron helped bend the veneer around the roundover without splitting. I'll try the other cabinet tomorrow...hopefully I'll have the same success.
). It would be nice to hear the Monitors versus the full-sized Statements in the same room (with the proper positioning of the speakers...the Monitors were built for 12" from the wall, and we heard them about 4' out from the wall).
