I have a unique problem that hopefully someone can help with. I recently did the most current software update to my SSP-800. I also own a CP-800. In addition 2 CA-M400 and a CA-5200. All of which has worked flawlessly until I did the software update on the SSP-800. The issue I now have is one of the CA-M400 amps does not automatically turn on when I the SSP or CP units are taken out of standby. Everything turns on/off as it should except for 1 amp. As designed you can touch any button on any item and it all turns on/off, except 1amp. If I touch the standby button on the amp in question everything turns on/off as it should. The only problem is if I touch any other button or use the remote everything turns on except 1 amp! To be sure be sure, I installed the most recent amp update software. I also have a CDP-502 in this circuit and it works fine. You can go to any any of the units with GUI and all info shows up as it should, you can turn the amp on or off, everything works! I can"t figure this issue out.
Any ideas?
See Ya,
Steve
Any ideas?
See Ya,
Steve
