The thread about the new adjustable qts drivers made me interested whether its possible for me to make a dipole from them. It seems so simple at first, attach the drivers to a MDF board, and attach boards to the sides making it into a 'H' or a 'U'. Like this one ---> https://www.htguide.com/forum/showth...ghlight=dipole After a brief research it seems to be difficult, or Im just not finding the right info. With other designs you can get a programs like unibox, and it do all the dimensions and graphs for you, I couldnt find anything like that for dipoles. How do you figure out the physical dimensions etc of the structure you're mounting the driver to?
All I could find was general info and specific instructions for a project like the Phoenix, from this site : http://www.linkwitzlab.com Alot of the content there is completely out of my scope; I get the impression that DIY dipoles are for people with engineering degrees due to little coverage and its unconventionalness.
Then theres the equalization, some people do it by producing their own circuit, and others use the behringer digital EQ. Is mechanical eq, like the new drivers with adjustable qts, sufficient alone?
Anyone like to briefly outline the key steps that led to their dipole creation?
