Dirt cheap DIY sub
  • Brandon B
    • Jun 2001
    • 2193
    Dirt cheap DIY sub
    A (non HT) friend mentioned he was going to go buy a cheap sub for $150 at some local store. I said I thought we could put one together for that which would kick its ass.
    Given spending about $90 on a parts express plate amp, anything better in drivers than one of these to get down to 30Hz for under $50?
    BB
    Let me look in my driver stash the basement. I probably have something better than that PE driver.
    Nothing I have will be shielded, is that necessary?
    • Brandon B
      • Jun 2001
      • 2193
      Probably not.
      Thanks for checking.
      BB
        Brandon,
        I have a NOS 12" Gold Sound 1240 DVC driver
        $35+shipping
        I shot some pics of it but my CompactFlash reader died, so I can't get them loaded into the PC
        Driver has a dual 2 layer 2.5" VC's, black poly cone, very heavy gauge chrome plated stamped steel frame. Although brand new this is a older driver than the ones listed on the website. It has a foam surround and felt dust cap.
        Should be used in a ported cab given the low Xmax
        • Brandon B
          • Jun 2001
          • 2193
          Looks like a good deal to me. I'll talk to my friend today and get back to you.
          BB
          • Brandon B
            • Jun 2001
            • 2193
            Friend says yes please, thank you very much. Send you a check? Check can be from me since your are better acquainted with me than him.
            He's gonna go with this for the amp. Unless he opts to spend $20 more for the 200 watt one.
            Happen to know offhand what the optimal vented box volume and vent length/diameter are, or if they are on the mfr site? Found a reference to a 2 cubic foot cabinet for the current model, but nothing for the port.
            Or remind me the name of the free/demo sub modelling program and I'll go find it.
            BB
            • Brandon B
              • Jun 2001
              • 2193
              Where'd you go, Thomas?
              BB
                I'm around it's just been a very busy last couple of days.
                Send me his address and I'll send out the driver
                Unibox is our choice for freeware.
                If you want a quick and dirty online calculator use these links
                Their referencing the 18X18X16 box because that's preassembled box size they sell.
                Bigger is better for the box size for low excursion drivers. Tune it around 25Hz, use a 4" diameter flared port (PE 268-352) if he can afford it. If the added cost is a big deal then use 4" dia PVC.
                For the $20 difference I opt for the bigger PE amp. It's a good long term investment for a time when he can afford a better driver
                • Brandon B
                  • Jun 2001
                  • 2193
                  Looks like we'll be doing about a 7.9 cu. ft box with a 4"x4" (approx.) port to get about a 25 Hz box. Won't get him to reference, but in his house plenty of thumping.
                  I'll post pics when we build.
                  Thanks for all your help Thomas, he's pretty jazzed.
                  BB
                    Wow, that's pretty big box!
                    Remind him that's a low Xmax woofer, not a Shiva :wink:
                    Line the inside of the box with some fiberglass insulation, or polyester batting.
                    • Brandon B
                      • Jun 2001
                      • 2193
                      Was gonna line it.
                      The numbers were run with .6" as the Xmax. Should that have been cut in half? Assumed it was 1 way, not p2p.
                      BB
                        An Adire Shiva is 1.29" P-P (16.6mm Xmax, one-way). The Gold Sound driver is about 1/2 that.
                        Not to worry, if he blows it up; I'll have a bunch of lightly used Shiva's available in a month or so. It will drop in the same cutout as the Gold Sound
                        As a reference you might want to checkout the ported Shiva applications papers
                        • Pat
                          • 1637
                          :E Uh Oh...what do you have up your sleeve now Tom?? 8O
                          Pat's Page
                            Hi Pat,
                            Last year Adire offered a preorder sale for their DPL12"s. I bought quite a few drivers with the intent of replacing the Shiva's in both my IB's. I meant to do this exchange quite a while ago, but got side tracked with other projects.
                            When time permits (probably mid to late fall) I'll put in the DLP12"s, then have a fire sale on used, but not abused Shiva's..... :wink:
                              • 16507
                              What do you hope to gain with the DPL12's over the shiva in your IB install?
                              • Ten 99
                                • Apr 2004
                                • 133
                                storage space that they're taking up!
                                  Andrew,
                                  They'll just play slightly lower with less EQ. Not a really big difference, the price on the DPL12"s was too good to pass up.
                                  Originally I planned on using them for dipole projects like the Arvo Design. But we went with the TC-Sounds drivers there, so the fall back plan is to use them to populate the IB's
                                  • Pat
                                    • 1637
                                    Slightly lower with less EQ...umkay
                                    IIRC wasn't big IB putting out a useable 4hz :E
                                    LOL...who am I to question the ways of the the poohba
                                    ;x( ;x( ;x( ;x( ;x( ;x( ;x(
                                    Pat's Page
                                      Hey guys, what's happening with this project?
                                      • Brandon B
                                        • Jun 2001
                                        • 2193
                                        I am in Tokyo this week. Left Chris with a bottle of Gorilla glue and a bunch of rectangles of MDF and all my longer bar clamps.
                                        In theory when I get home he'll have a box of sorts. And stained fingertips.
                                        I'll post then.
                                        BB
                                          • 8938
                                          :rofl:
                                          Hehe, another soul lost. . .
                                          • Brandon B
                                            • Jun 2001
                                            • 2193
                                            Well, I am going to his hyouse to see this tonight. I will make sure I get a pic or two to post.
                                            He also bought the Parts Express $140/pair monitor kits and is pleased as punch with them compared to his old Costco bargain speakers. Let you know what I think of those as well.
                                            BB
