Carmody's Swope 3-way vs Classix 2.5 build suggestion
  • Fractals
    • Dec 2018
    Hello all!
    I'm ramping up for a new project build and am trying to decide between Paul Carmody's Swope-3 way design vs. the Classix 2.5 (to act as the L/R mains).
    I built the OS MTM in a transmission line a few years ago (build log here), and while those are fantastic speakers, I am wanting to upgrade a bit. They will serve two purposes: music and home theater aprox 50/50. For some reason I keep having issues signing up on the techtalk forums, so I thought I'd give it a shot here.
    our living room is modest size (15' x 12') with an open plan into the kitchen directly behind it.
    Cheers!
    Last edited by theSven; 03 May 2023, 20:10 Wednesday. Reason: Update image location
  • chrisn
    • 166
    I'd probably go with the Swope 3 way ( i can't find a link to it ). This might bridge the gap between the two you mentioned: https://sites.google.com/site/undefi...classicrevival
