Classix 2.5 Done!
  • cousinjerry
    • Sep 2008
    • 5
    Classix 2.5 Done!
    Hey Everyone,
    Don't post much at all but do hang around reading all of the great information here and thought I would post the finished product of Paul's Classix 2.5. It was a few months of sneaking away to the garage for an hour or 2 but managed to pull it off with only 1 major mishap. Anyways, here's the finished product (and a few of the build. Please excuse the mess of a garage...) -
    And the mishap while flush trimming the baffles. Live and learn...trim slowly....
    The box is finished in wood glue/water mixture, bondo, primer and then a few coats of epoxy appliance paint.
    The baffles are curly maple with walnut on either side and then finished in 4 coats of Waterlox Original.
    I couldn't be happier with both how the look and more importantly how they sound. They easily fill my main floor with only being run from a little Lepy 2020!
    Thanks!
    • 1891
    Finished speakers look great ..... painful lesson on the baffle trimming, looks like you were trying to remove too much material in one shot?
    • cousinjerry
      • Sep 2008
      • 5
      You got it... That along with the grain going in the direction it is. Took very light passes on the new one.
      • chrisn
        • 166
        They look very nice. Are the cross braces cut from one piece? Crossover looks nice and tidy!
        • cousinjerry
          • Sep 2008
          • 5
          Thanks! Yep. Just the size of the top and bottom withe the 4 corners cut out and rounded over quickly on the table.
