Hey guys,
although the TL tweeters are barely used here in Europe, they seem to be very good considering the rewievs from the US diy Hifi boards....
Does anybody of you did comparisons between the different versions made of ceramic, magnesium, composit or beryllium? Any listening impressions or recommendations?
I considered the ceramic N26CR2-G but can not really explain why, just intuitive. What is the main difference between that driver and the older square N26C?
Is there a waveguide existing that will match well with these tweeters? Pellegrene had something, but his website ist down...
Maybe the bigger Jantzen waveguide will fit? I am not sure about the whole diameter of the N26 incl. the surrounding of the dome, sure the voice coil is 26mm ;-)
Any advice is appreciated!
Thanks and kind regards,
Stephan
Stephan
