I decided on building statements for the home stereo/theater. I will build the Full,and center statements. I am not sure if I should build 2 extra centers and use them for the surround or should I build 2 monitors statements instead. I am a newbie so any suggestions will be appreciated. I also plan to use the EMOTIVA xpa-5 and a marantz sr6007 as sort of my pre-amp/processor. I did not go with emotiva's pre amp or surround sound processor. I like the options on the marrantz. Any thoughts on this folks.
getting it together.
You are aware that the Statement Monitors require at least 12 inches of space behind them for them to operate properly, right? So if you build the Statement Monitors you cannot mount them to the wall.- Bottom
If you have sufficient space to adequately place and sufficient budget to build them, the monitors will be the best possible surround for the Statements, I'm sure.
I find them to be a bit "overkill" as surrounds, though ... but it could make sense for actual surround music I guess.
Personally I went for 4 F4's as surrounds in a 7 channel setup. You could also go for R4's ... they should also complement the Statements well as they use the same drivers, but lack the woofer.
Make sure to start a build thread ... I know I can speak for all of us when is say that we like pictures- Bottom
