Interesting Drivers
Yes these really do look nice. Marketing usually fluffs up cone materials to be something that they are not. Graphene coated magnesium anyone? But these appear to actually do what was hoped. Pistonic operation through the speakers useful passband and relatively mild breakup. I do wonder how that 5kHz breakup will manifest in the HD.
Trouble is they don't have a dust cap. So I can't turn them into a coaxial -.-What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
Now with website. www.5een.co.uk Still under construction.- Bottom
SATORI MW16TX-4 has an Le of just 0.15mH.... cone breakup is not a problem and should return excellent IMD. This is a woofer and not a midrange but it could be used as a midrange, and perhaps it is the new transient king. But lets wait for the MR series and see what they will offer.- Bottom
Well you know...I had considered it.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
The 5Khz breakup looks very benign compared the fierce breakup of aluminium or magnesium cones.
I'd like to see third party data, but it is possible this is better than the metal Satori some have been asking about.
Any of our favourite dealers doing pre-orders?- Bottom
well, that's definitely a significant improvement! A WO24 with this technology would be very interesting...the AudioWorx
Just ask Mr. Ohm....- Bottom
Satori TeXtreme tweeter to be released (next month).
TW29TXN
Satori TeXtreme Woofers to be launched
MW13TX, MW16TX, MW19TX and WO24TX.
Satori Midrange to be released
MR13 & MR16
The midrange and woofer series is expected to be available by summer 2020. Preliminary information. Ulrik also mentioned that he did work on a Satori 13.5" woofer as a prototype but was not released, I among a few others have expressed an interest in this so who knows. Maybe Ulrik investigate and do some R&D on it for the TX line. That would be awesome wouldn't it- Bottom
If you don't want to wait for the TeXtreme, there's the look-a-like Dayton Epique series, which appears to have the same motor and basket as the Accuton drivers but with a damped carbon fiber cone. Though breakup peak of the 5.5" driver is 10dB at 5kHz, which is not as good at the TeXtreme, it does offer very nice efficiency. I'm waiting for someone to try it.- Bottom
..it's not like anyone cared, but:
In this Test Bench, Vance Dickason characterizes the SEAS W16NX003 5.25” midbass driver, one of the new graphene-coated magnesium cone drivers from the brand's Excel Graphene range. This product line has been an ongoing project for more than two years, combining the already highly prized magnesium cone with the desirable acoustic properties of Graphene, which also works to provide corrosion protection to magnesium. This article was published in Voice Coil, August 2019.- Bottom
The distortion peak at 1kHz is likely from not chamfering the rear baffle. Otherwise the distortion numbers are amazing, so is the high power output and ~8mm linear xmax. This is a bass monster relative to its size. Should sound absolutely amazing in a small 2-way. Seas Excel puts Accuton to shame by the ear test.
Other drivers measured in the same way don't show this distortion peak. Don't know the cause and if it's real or not.- Bottom
The 3rd harmonic distortion is a clear improvement Vs SEAS old motor geometry but this was to be expected. It's now on a par with SBs standard line. Still with the diminishing 3rd order Vs rising frequency it pretty much hides the worst of the distortion amplification from the cones resonance. It is still there it's just before SEAS motor geometry caused a general rise in 3rd order that was then made much worse by having a distortion peak at the end of it. Now the 3rd order goes down with rising frequency with a peak at the end. This is a nice, much needed, improvement.
If that 2nd order isn't a measurement artefact, and we have no reason to believe that it is, then we've got a glaring fly in the ointment. This should not be there. Actually a hump appears in SEAS own measurements at 1kHz too, or something similar at least. How bizarre for their magnesium cones. What a shame the driver was looking nice but the hump, if Vance's measurements are accurate actually makes using this driver more of a pain too. Not that I was ever going to use them. Far too expensive for me. I am curious to see how the W18 will measure and eventually the W15.
No one complains about the 2nd order peaks with soft cones because 1) they are impossible to hear. 2) There isn't anything you can do about them. Soft cones are flawed by design in this respect and you accept this pitfall for the benefits they provide. You go to a stiff cone if you're looking to avoid the 2nd harmonic and frequency response wobbles that come with it. Metal cones should not show this behaviour so I am complaining about it. Why bother with the metal cone at all if it's got a similar, but different, problem Vs a soft cone.
Roll on textreme.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
"I set the SPL at 1 m for the W16NX003, mounted in free-air using a pink noise stimulus set to 94 dB (my standard for home audio devices), which required 4.55 V. With the microphone placed at 10 cm from the dust cap, the W16NX003 produced the distortion curves shown in Figure 10."
In this Test Bench, Voice Coil characterizes Dayton Audio’s new 4.5” diameter carbon fiber cone midwoofer, the CF120-4.
However, when I did the measurements using a thin front baffle, the distortion was well under 1% throughout the area:
This means that for some drivers, the rear chamfer is very important so that there is room for the rear air to breathe.- Bottom
Waiting patiently for the 7.5" Textreme version. This range will be a good alternative to Accuton. Maybe SB shd develop a grill for car installs a la Morel- Bottom
Noticed at a recent show that Revel are no longer using the SB ceramic drivers. No ribs on new cones. Guessing Harman Group have these made in house now?- Bottom
I noticed this too then wondered if their ceramic line ever had ribs right from the start. The alu drivers did but I can't seem to find any ceramic revel that have ribs. Correct me if I'm wrong.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
The ceramic range def used the SB drivers at the outset and plenty of glowing reviews with these drivers. Then I'm guessing the (Samsung?) buyout meant a trimming of costs. Slightly worrying times in the hifi industry, with all these groups swallowing up famous names and dumbing them down- Bottom
..better, but it still has virtually nothing to do with Graphene coating:
On this edition of Test Bench, Vance Dickason continues to measure one of the most anticipated driver designs launched in the market in 2019, from SEAS's new Excel Graphene line. Following the previous Test Bench on the W16NX003 5.25” midbass woofer, this one focuses on the W18EX003 6.5” midbass driver. This article was published in Voice Coil, August 2019.
-and still a pointless driver considering the cost.- Bottom
Agreed. Vance made a boo boo in the review as well it would seem. He says he tested it at 104dB for the distortion measurements, which is clearly incorrect when you compare it directly with the W16 which was tested at his usual 94dB. The bass distortion should be significant higher on the W18 if that was the case.
It's a decent driver (there's still some second order issue that the old W18 never had), but as you said, nothing to do with the graphene. And a prohibitive price where, if we are paying a significant premium for the graphene part, most of us are paying for something we don't want or need.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
I believe that their corporate focus is largely on automotive infotainment systems. They may sell more Revel through Ford (Lincoln) than they do through traditional hifi dealers.Welcome to Rivendell, Mr. Anderson.- Bottom
The graphene is necessary to prevent corrosion resistance on the magnesium cone. I don't know if it makes any difference in sound, but I guess only subjective listening tests will give us a hint. I guess they probably could have just painted the cones.
I'm glad Seas updated the Excel motors because it was falling behind the competition. Now they look amazing.- Bottom
The excel cones have always had some sort of coating applied. No idea what it is but it apparently wasn't enough. Yes the graphene coating is supposed to stop the cone from corroding but the vast majority of users don't need it. Hence paying for something that we don't need.
It's one thing to upgrade the coating on the cone as an incremental improvement for £1. And let's face it there are loads of inexpensive anti-corrosion agents formulated for cheap and effective protection. But it's another entirely for them to be charging, what looks like, a £200 premium for. If you live in a climate where corrosion isn't a problem that's a lot of money you're paying for nothing. To be honest in any other kind of industry the coating would have been upgraded as a basic manufacturing improvement at no extra cost years ago, but SEAS has gone down the audiophool avenue this time round.
My W15CYs are coming up to 20 years old and are as good as the day I bought them. I think they cost around £100 each back then too, including tax and shipping.
The motors were in dire need of improvement but in terms of material/manufacturing cost may even be cheaper than the old designs. In terms of the R&D costs and the FEA software simulation stuff. This is something SEAS had been way behind the times with already. This is not a new technology, FEA optimised motors have been common place for 10+ years. Then what they manage to produce are as good as SBs standard range.
So basically we're paying through the tooth for SEAS being late to the FEA party and a graphene coating most don't need. If anything FEA simulation should reduce R&D costs because it basically allows you to do almost all of your design work in software. Whereas before SEAS would have had to have built loads of actual prototypes. With metal tooling this is a pain staking, time consuming and expensive process. With FEA you alter a number/change a geometry, press a button and have your revised pole geometry answer in minutes, not days/weeks. How else do you think SB effectively eliminated cone resonance amplification in their NAC/CAC cones? FEA cone simulation.
Sure I sound like a negative ninny and sure these new excels are an improvement in most ways. But from an engineering standpoint these are not improvements that we should be paying much, if anything, for. The improvements being 1) fixing a faulty product (the cones should never have corroded in the first place) and 2) paying for SEAS FEA software which should only save them R&D money and increase their profit margins.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
So I have in my hands the new W16NX Graphene and SB15NBAC aluminum cone, and I will compare them as they are similar. The harmonic distortion profile of the SB15 is essentially just a straight line that increases in the lower frequencies based on increasing excursion alone. It's extremely clean, though I expect the Excel unit to beat it at higher output based on its excellent Klippel results and overall bigger beefier motor. I'm going to measure my W16NX units soon to comapre. You won't be able to charge $8000 if you make a small monitor using the SB15s though.- Bottom
Power handling is rarely of any realistic concern in domestic loudspeakers and this does not justify the price hike in any which way.
I don't want to buy or sell $8000 speakers and they should be better than the outgoing model. The new Graphene drivers are an improvement over the old.
The point is that the pricing on the new excel line is based completely on the charge what you can, not what it's worth ethos. SB on the other hand balance their pricing far closer to the what it's worth end of the spectrum. This is to be greatly applauded.
A good engineer solves the problem he is tasked with.
A great engineer also solves the problem but does it for half the price.
We all know the audiophool sector tends to throw away good engineering for snake oil monikers and obscene price tags.
Ooo Graphene - let's charge 2x the price. Not to mention the pricing on the prestige range is absurd too when directly compared to SBs drivers.
This is not to say that the new SEAS drivers are bad, they aren't, they simply are not worth the price in terms of actual value for money. And I rate value for money very highly.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
So I have in my hands the new W16NX Graphene and SB15NBAC aluminum cone, and I will compare them as they are similar. The harmonic distortion profile of the SB15 is essentially just a straight line that increases in the lower frequencies based on increasing excursion alone. It's extremely clean, though I expect the Excel unit to beat it at higher output based on its excellent Klippel results and overall bigger beefier motor. I'm going to measure my W16NX units soon to comapre.- Bottom
[..]Still the price increase is justified. [..]
So I have in my hands the new W16NX Graphene and SB15NBAC aluminum cone, and I will compare them as they are similar. The harmonic distortion profile of the SB15 is essentially just a straight line that increases in the lower frequencies based on increasing excursion alone. It's extremely clean, though I expect the Excel unit to beat it at higher output based on its excellent Klippel results and overall bigger beefier motor. I'm going to measure my W16NX units soon to comapre. You won't be able to charge $8000 if you make a small monitor using the SB15s though.Welcome to Rivendell, Mr. Anderson.- Bottom
Putting aside retail costs, for the moment, does the W16NX003 or W18EX003 set any new benchmarks for a mid-woofer?
I mean H2 of ~2% and H3 ~1%, @40Hz with a drive level of 4.55V and 5.29 respectively, is this class leading or class beating?
For a 5.5-7" midwoofer?
Vance's standard is
"I set the SPL at 1 m for the (DUT) mounted in free-air using a pink noise stimulus set to 94 dB (my standard for home audio devices), which required x.xx V.
With the microphone placed at 10 cm from the dust cap, the DUT produced the distortion curves shown in...- Bottom
Vance's standard is
Based on the 15cm Wavecor just tested, I'd say the answer is not really. Plus, SEAS isn't aiming for improvements in bass, typically, but in the upper midrange/treble. There are better drivers out in the wild for bass (e.g., Anarchy, Wavecor Balanced Drive).Welcome to Rivendell, Mr. Anderson.- Bottom
What is on the test bench? The famous expression "All roads lead to Rome" in the context of today should read "All roads lead to Denmark". I will not be mistaken if I say that most home speakers up to the very top class are currently being assembled using speaker drivers with Danish roots. Judge for yourself: Peerless Vifa ScanSpeak SB Acoustics Dali Dynaudio Wavecor Timphany- Bottom
