I am working on putting together my first real (currently have HTIB) HTS. I have been doing research for a couple weeks now. I am convinced I want to try building my own speakers.
I am planning on purchasing a refurb Onkyo TX-NR709 for $450. THe other option i considered was a new Onkyo 616 for $390. I believe the former is a better buy.
My budget for getting my speakers started is $1500 with room to add/grow in the future. My living room is large 22'x22' ish. It is connected to an adjacent kitchen with only a 3ft wall in between. I understand that my budget probably doesnt allow for a "proper" system for my room but I plan on getting the best I can with that budget for now.
I have been told that Ascend Acoustics 340 L/C/R would be a good place to start and eventually adding their HTM200's for the rears. Also, I would eventually a sub if it doesnt fit into the budget up front.
The advice I seek is in the selection of a comparable DIY design. There are tons of designs out there and its hard to choose. I am still very interested in DIY route. I have been looking at the TRITRIX set. But the "budget" label makes me wonder if I will be happy with them. The other set that has caught my attention from the same design team is the AviaTrix. They seem to be based off the TRITRIX but a step up with better drivers. What DIY speaker are comparable to the Ascend Acoustics for around the same price point?
I am looking for a system that will serve as a 5.1 and also great for music listening. I plan on driving them with the receiver for now until I can afford an amp if it is required.
Thank you in advance for any guidance.
