I have a Mirage 8" sub now that I would like to replace with something a little bit bigger. So I have been reading about subs for a little over a year and I'm still a little unsure of some things. I've played with WinISD and looked at Unibox, but I don't really understand what I am trying to get from them.
What I want is a sub that will play low, (don't I?). Its main use is for movies (I have Triton mains right now but will probably replace them with Swope 3 ways or Kahns). It will be in a big room that is 1/5 open to the rest of the house. I know I want to use a plate amp and not a separate.
Whenever I look at a sub woofer I look at the Frequency range and look for the lower number. I had for a while thought of getting the Titanic MK III 15" with the dayton 1000 watt plate but then when I looked at the specs it has a frequency range of 19 - 500 Hz. From that I thought I would be missing anything below 19 Hz but from more reading and WinISD I get the impression that it just drops off significantly below that.
I also read the AV Science forum and those guys seem to only believe in building subs that use 4-16 drivers, use external amps, and cost a lot of money.
So I'm not sure what I am asking exactly, I hate to say what do I need, because no one can really answer that. I guess I'm looking for some basic thoughts.
I like the easy button designs http://www.avsforum.com/avs-vb/showthread.php?t=1018171 There is one in google sketch up that uses a 15 inch driver and bash plate amp. It is probably what I would want to build.
Sorry for the ramble, but if it makes sense to anyone else, may I have your thoughts?
Wil
Wil
