Oh boy, this should keep me busy for a while. Can't wait to start this and at the same time a little hesitant knowing the perfectionist in me. They will probably take me forever for the finishing work. My last set of speakers I tried to finish (15 years ago I think), took foooreeever. I tried to get a piano black finish using spray cans and was never able to get them the way I wanted.
I now have a compressor and plan on getting a spray gun if I decide to paint. I may veneer though as it looks to be a bit easier to get better results.
I think I have read through every post on the various Statements builds over the past 2 weeks and am officially cross eyed now.
Apparently I woke up the other night and said in my sleep "Is the speaker working?" to my wife. I kid you not. I don't even remember doing this. She said "yes it is" and i went right back to sleep 8O
I am trying to decide on the sealed or Ported. I plan on building the Statement Center and a sub to go along with the mains. I have read all the posts about the pro's and con's of sealed vs ported, but there are a couple questions still unanswered in my mind before I make the decision.
1) I believe it has been suggested for the sealed, to cross it over at 50hz with the sub? My question is in stereo music, if you have one sub playing from 50hz down, would you lose the ability to tell where instruments are playing? Is 50hz low enough that you do not need to know the positioning of the instrument? I'm not sure if I am being clear enough. Let me put it another way. I believe one of the objectives of stereo, is to be able to put instruments through different speakers if needed. What happens if an instrument is playing in the left speaker, say, and it goes low enough that the sealed Statement can no longer produce the sound and that is now the job of the sub.
Wouldn't the sound then come out of the sub and you lose the purpose of the intended recording? Or is 50 hz low enough that it is no longer directional and it would be ok?
2) Do you lose anything at all (dynamics, etc), if I were to go sealed with sub? (it appears sealed is the way to go if you have a quality sub). Would there be any reason's at all why I would not want to choose this method as opposed to the ported version with a sub? I've never had a sub before so I don't have any experience how a good quality sub integrates for music. Is it too overpowering or it will be played the way the music was meant to be played?
I am going to be ordering all my parts for the Statements and the Center (as the ported and sealed use the same crossover) and hopefully you guys can convince me one way or another which way to go.
Chris.
Chris.
