4 woofers walk into a bar...
  • augerpro
    • 1871
    So I gotta question for you guys...say I were building a 3 way with 4 woofers. I've read that woofers in series can have an unforeseen impact on the bass alignment due to slightly varying TS parameters. If I were aiming for an 8 ohm nominal woofer section I can wire it two ways: a pair in series wired in parallel with the other series pair, or a parallel pair then wired in series with a following parallel pair? Which would you pick? Do you think there is any difference?
    ~Brandon 8O
    DriverVault
    Soma Sonus
    I would have thought that having 4 woofers together would perhaps help in smoothing out any spread in TS parameters?
    Going the route of two pairs wired in series, this would allow you to use separate filters to each pair if needed. This might be a good thing depending on how the drivers are positioned, relative to the midrange and the floor. You could end up with a 3.5 way.
      Wire them in parallel pairs, then series the two pairs....
        Would you mind explaining why? :T
          In a PA setup, you'd do it Thomas's way so, if one speaker burns up, it's the only one that dies. If you do it the other way, two speakers die and you can't tell by listening which one is fried.
          • numberoneoppa
            • 535
            From an impedance standpoint alone, it would simplify things. (z*2/2=z)
            -Josh
            • augerpro
              • 1871
              Thanks for the input guys, I'll take it into consideration.
              ~Brandon 8O
              DriverVault
              Soma Sonus
              • bottlebrush
                WOOFERS WIRED IN SERIES-Help Please
                by bottlebrush
                I am considering building an WWMT, using two 8'' or 10'',4 ohm woofers wired in series to give 8 ohms nominal. Bass performance is very important to me(not boomy,but tight,accurate and punchy). :roll: Can anyone give me some serious reasons why this will not be satisfactory,compared to 8 ohm woofers...
                29 October 2007, 20:19 Monday
              • Jed
                2.5 way cascaded 3 woofer series parallel
                by Jed
                Hi, after evaluating my choice for a higher Xover point at around 3K, I decided that a shallow crossover slope and high crossover point such as 3K would not be optimal for an MTM configuration that I simulated previously. So now, I'm looking at an MTMM 2.5 way with a cascaded X-over network with the...
                30 January 2006, 19:15 Monday
                2021-2023 Isiris Update
                For various reasons it makes more sense to me to have a succinct new thread covering the investigations and updates this year for the Isiris. Only a few key items that will be addressed right away, but there might be more soon if the negotiations for early samples of a new midrange are completed. ...
                27 June 2021, 21:07 Sunday
                250 watts Bi-amp VS 400 watts Bi-wire?
                by Race Car Driver
                A question thats been lingering....
                Now, say you had a pair of speakers, with bi wire posts.
                Now heres two scenarios.
                1)Take those speakers and hook them up to...
                *Each speaker gets a mono block, bi-wired, rated at 400watts RMS 8 ohms
                (400...
                16 December 2005, 20:46 Friday
              • BigT
                Woofer Configuration? Also, Series vs. Parallel?
                by BigT
                I want to use a pair of 15" woofers for my 5-way quad-amped speaker project (main speakers are 4-way, with subwoofer makes it 5-way). I will be aligning all driver centers on a vertical line but if I mount both woofers this way, the speaker will be taller (~60" or 5") than I'd like with...
                25 March 2008, 11:29 Tuesday
