Are loudspeaker diaphragms acoustically transparent?
  • thadman
    • Jan 2007
    • 248
    I'm in a bit of a dilemma, I'm not sure whether or not loudspeaker diaphragms are acoustically transparent or the degree to which it effects their motion.
    A few ideas,
    Below the fundamental mode of the enclosure, the air behaves with a single phase. The acoustic forces (and their effects on diaphragm motion) within the enclosure could be described accurately by the air compliance.
    Within the modal region of the enclosure, the air has a multi-dimensional phase property, however Ray acoustics still do not apply. The acoustic forces (and their effects on diaphragm motion) within the enclosure could be described accurately by analyzing the modal surface encompassing the diaphragm.
    Above the Schroeder frequency of the enclosure, we'll assume Ray acoustics apply. In this region, acoustic waves should be propagating through the enclosure space (ie reflections will be present due to the impedance mismatch between the air and enclosure walls/diaphragm). It is over this bandwidth that the effects of the acoustic transparency of the diaphragm have me curious.
    At the interface between two dissimilar masses, an impedance mismatch is found. This is the reason we observe reflections.
    Above the Schroeder frequency, reflections are believed to occur. If we assume a reflection occurs, we must also assume the presence of an impedance mismatch.
    Let's assume we have two masses (Mass A = air, Mass B = loudspeaker diaphragm). We assume a propagating wave (Mass A --> Mass B) contacts the interface between the two masses. At the interface we observe a reflection (wave is reflected back to Mass A), however some of the energy is absorbed by Mass B.
    Wouldn't this dictate that propagating waves have an influence on diaphragm motion due to the impedance match (ie 100% reflections are not observed) and we must thus consider their influence if we wish to accurately simulate a loudspeaker system?
    Over what bandwidths should the impedance match be considered?
    If any of my assumptions are inaccurate or incomplete, I would much appreciate some feedback.
    Thadman
  • thadman
    • Jan 2007
    • 248
    Anybody?
    • Piotr
      • 102
      At such high frequencies.. wouldn't most of us get rid of the energy with the box stuffing?
      I say it's not an issue in a properly designed box.
      /Peter
      • David G
        • 170
        The physics is way over my head, but I recall that Martin Colloms discussed this a little in his book entitled High Performance Loudspeakers.
        He showed some CSD plots which clearly showed a reflection off the back wall of the enclosure coming through the cone. I have always considered cones partially transparent in the midrange, and hence prefer large enclosures with lots of stuffing.
        • thadman
          Enclosure resonances, not a big deal?
          by thadman
          One of the recent trends in loudspeaker design has been to incorporate dipole or open baffle alignments into the design. This has the obvious benefit of removing resonances within the body of air behind the diaphragm, but can this same result be achieved through another technique?
          As...
          18 May 2009, 11:17 Monday
        • Nateadwg63
          Help with a cutsheet for a subwoofer
          by Nateadwg63
          Howdy all...
          I have a driver selected to build two 10" vented subwoofers. I have the specs for the driver and the manuf. recommended vented box size, but I do not have the proper software that will give me a cutsheet that shows the correct way to cut and where to place the driver...
          05 February 2009, 15:13 Thursday
        • Clive
          Home Theater Glossary
          by Clive
          G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
          I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
          11 July 2005, 22:38 Monday
        • thadman
          Loudspeaker mass normalized mode shapes
          by thadman
          I'm interested in calculating the mass normalized mode shapes for various loudspeaker diaphragms for simulation purposes in order to have a more complete understanding of their behavior.
          I believe mass normalized mode shapes are scaled such that
          p*A*Integral of (mode)^2...
          23 July 2009, 10:40 Thursday
        • thadman
          Loudspeaker impulse response optimization
          by thadman
          I'm interested in what factors affect the impulse response of a loudspeaker driver, specifically the relationship between the factors.
          If we are interested in optimizing the impulse response of the loudspeaker system, could we simplify the problem by parameterizing the system and separating...
          17 April 2009, 15:01 Friday
