Dayton ND-90... what is it?
  • fjhuerta
    • 1140
    Is it a mid? A line-array driver? A multimedia woofer? :E
    Javier Huerta
    It is Nice. That's what it is!
    • kirknelson
      • 89
      Looks like it's a full-range-line-array driver, according to Mr. Murphy's review and link. Hopefully he'll be posting some measurements on his site.
      • jkrutke
        • 590
        Hmm, looks like a re-badged Aura NS3. Decently smooth wide range driver, but it would have some serious competition in the 3" Fountek or the RS100. Unless there's something different on the inside, but externally it's an Aura NS3.
        Zaph|Audio
        • fjhuerta
          • 1140
          Hey Zaph, since you are here, THANK YOU for your efforts on the Energy C-500. It's a very interesting set of articles.
          Javier Huerta
          • cotdt
            • 393
            It says it has 20mm of xmax.
            • Landroval
              • 175
              I'd say that's more like xmech peak-to-peak. I bought a bunch of the ~pre-production version of this driver when it was caller the RS90. Very close to the Aura NS3.
                • 5204
                Didn't Dan N. use the RS90 in one of his projects?
                  • 1456
                  Yea, Ryan, I used it as the mid in my SoundRounds. I loved the midrange it has. This is not the same driver, however. Mine was sold as a HiVi B3A-B buyout, but it was well known that it was the ill fated RS90. It was not Neo and used a round cast frame, not a stamped steel frame.
                  Dan N.
                    • 5204
                    thanks Dan.
                      • 15290
                      4 mm linear Xmax, does look an awful lot like an NS3 performance wise., including the very low sensitivity (80-82 dB). But what do you expect with that cone size and that much Xmax in a small driver? With an RMS power rating of 20 watts, it will produce about the same SPL as a more conventional driver with an RMS power rating of 5-6 watts. Might make a cute small MTM for lower SPL applications with the right tweeter, if you can keep the crossover low enough in component count.
                      • fjhuerta
                        • 1140
                        It even says it's a direct replacement for the NS-3. With that sensitivity, a dedicated midrange is out of the question. I can only imagine it working with a line array.
                        Javier Huerta
                          It should do quite well as a computer speaker or similar, also.
                            • 1456
                            Oh, I beg to differ guys. I used a pair of the HiVi B3A-B (the original Dayton RS90) in a WMTM in my SoundRounds omni project with an Aura NT1 tweeter and a single RS225. The SoundRounds won their category (under $200 driver cost) at Dayton and won the budget class at Iowa in 2008. Don't sell these drivers short for a midrange in a low spl system, assuming they perform close to what he original RS90's did. They did a pretty good job of filling that theater in Iowa.
                            SoundRounds
                            Last edited by theSven; 07 July 2023, 17:22 Friday. Reason: Update image location and htguide url
                            Dan N.
