Lunchwagon's MiniStatement Build
  • LuncHwagon
    • May 2009
    • 44
    After building the recession busters, I got hooked. I thought the Minis would be a good project to get me started. I have a little bit of woodworking experience, so I thought I would try a few things differently.
    1. I dadoed all the joints. 1/4in for depth, then just added 1/2in to the horizontal width and each of the joints. It all fits tight and leaves the end piece with the exact dimensions/Internalvolume of Jims Design. Just something a little different. Ive seen a few others do it. No skill in that area, so using MDF is the best trial wood there is.
    2. For ease of cuts, I cut all the horizonal pieces the same. This kept my workflow simple. The open "tunnel" horizonal pieces were just opened up with an arc. You can see those in the pictures. I cant imagine that it will change the sound compared to the 1" strips in the design.
    These are my unsanded, dryfit pictures. With the glue and clamping all the joints are tight, flush and square.
    Next up is crossovers and backs... These are going to have a solid wood baffle with the rest being in a glossy black.
  • pocho
    • May 2009
    • 23
    Its a nice start
    Looking Good
      • 3223
      Hi Lunchwagon,
      Excellent work so far! I'm looking forward to following your build and hear your thoughts when you get done.:T
      • BeerParty
        • 475
        Are you planning to laminate the front baffle (solid wood + MDF) or are you planning to make the entire front baffle out of solid wood?
        My Statement Monitors Build
        My AviaTrix Build
        • LuncHwagon
          • May 2009
          • 44
          The plan for right now is a solid wood baffle. I have some concern of warping, still up in the air here. With all the relief of the cutouts, the narrowness of the piece, and the strength of the glues...and prob a biscuit or two...should be solid. Thoughts are welcome and appreciated.
          My second choice is going to resaw several pieces of the solid wood and make my own "plywood." This requires staining to blend the ply. I've done this before with great success (albiet not for speakers)
          MY third option is going to be a lack of hardwood altogether. I would have the baffle a different color than the rest.
