I am wondering about port location options and baffle material. So...
#1. Will moving the port to the rear change the way they sound?
#2 If a rear mount is ok, what is the best way to get that port mounted? ie. recessed from outside or inside? support needed for internal flare?
#3 I want to use a solid wood baffle for aesthetics and Im not a huge fan of veneers. I want to bookmatch some pieces. Any reasons not to do this?
Thanks...
Thanks...
