I have recently completed my Nat Ps for LR mains with accompaning bass bins. Along with the WTMW CC these are just crushing my poor Infinity Alpha 20s that I have regulated to surround duty. My room is roughly 3200 Cubed and the floor is 15 by 20 for the theater area. I have looked at the Modula MT and the D44 designs along with the Tri Trix designs. These must be Non BSC. I would appreciate some help. Any other designs are welcome as well.
Need new surrounds
Tags: None
Do you have enough room for a set of in-wall/on-wall NatP's?
Need to?
No, but....
The newer high-def DVD rear effects channels get completely discrete signals. So having larger speakers (like ones matched to the mains) is a nice thing IF it's in the budget and there's room to put them.
Otherwise I'd go with the Modula MT.
But it's not that much less expensive than the NatP option....
And FWIW the newer multi-channel music discs really benefit from matched speakers
I hear you Thomas and it makes since. Yes I have the room and the budget. I would have to make them floor standers then. Thanks for the imput once again. As always Thomas is a great resource. One good thing about building another set of Nats is I already have the front baffles built. I have a 7.1 setup would 4 of these be to much for this size room?- Bottom
I think they'd be just about perfect for a 15'X20' room. You be able to move enough air so the drivers would never be stressed.
If you want something more modest use the Modula MT's on the sides, that would leave a nice match for 4.1/5.1 music
Just remember, Evil Twin himself recommends an "imperial class amplifier" (http://htguide.com/forum/showthread.php4?t=22626 third paragraph). The impedance stays at 4 Ohms for much of the frequency response and even dips dips below that around 2500 Hz. It is wise to heed the warnings of the Imperial Twin.
Later,
DonAlways do sober what you said you'd do drunk. That will teach you to keep your mouth shut. - Ernest Hemingway- Bottom
Don I have a first gen Emotiva for my front end and plan on using a couple Behringer A500s or an Emotiva UPA 7 amp. It all depends if I decide to go the Dolby 11Z route. Thanks for the input.- Bottom
