Polk Audio Monitor 60 VS MTM design with W5-704D and DX25TG
  • mintos
    • Apr 2009
    • 62
    I was trying to figure out if I can build a set of decent towers that can preform better than the Monitor 60 at 120 per pair (no tax, free shipping)
    Closest I've seen is the MTM desing with
    264-578 Yes Vifa DX25TG-05-04 1" Fabric Dome Tweeter
    264-850 Yes Tang Band W5-704D 5-1/4" Woofer
    Speakers with crossover cost $123.30. I figure the cabinet stuff will cost another $25.
    Will the 150 MTM sound better than the Monitor 60? It's looking like a great deal atm.
    Might want to recheck the price on the Polks. Most places are listing single speakers for $130.
    http://www.newegg.com/Product/Produc...82E16882290017
    • mintos
      • Apr 2009
      • 62
      Sorry I ment $120 per tower. There's a coupon code for $10 off.
        When I listened to CJD's RS150 MTM in my home versus a pair of: $1400 Paradigm Studio 40s, $800 DynAudio 42s, and $550 Ascend 340SEs, I clearly thought that CJD's were better. (And a year later asked CJD to design me my monster towers) So, yes DIY can provide much better speakers.
        BUT, you must have the tools and desire to DIY. Most people end up not saving money by DIYing after all the tools and time and effort. But, it is fun and keeps us out of trouble. I really don't recommend DIY speakers to save money.
        You might want to really consider the TriTrix design. It is in your budget and is very good. PE is also offering recesion buster kits and precut knock-down boxes for them now at an extremely reasonable price.
        http://techtalk.parts-express.com/sh...d.php?t=209947 This is 1/2 way between DIY and retail. So a good intro.
        • savage25xtreme
          • 305
          not sure how the monitor 60s sound but, I have some Polk R30's and my BAMTMs destroy them in every way, shape, and form... but come in at about $300 a pair for build components
          Gavin
          BAMTM Build
          • mintos
            • Apr 2009
            • 62
            I saw the Trix too, looks good. 5.25" woofers are probally better for base though. I don't want huge towers. I want to build a MTM design with
            260-142 Yes Dayton XO2W-2.5K 2-Way Crossover 2,500 Hz
            $23.07 $23.07
            $28.57 $28.57
            $24.70 $49.40
            Subtotal: $101.04
            I saw on this site a MTM design with those speakers. Only 22" long. I can probally for go some base for a smaller cabinet as I'll be using a sub.
            However, when I went to get individual components for the crossover, the price was not exactly what I wanted. I see that the prebuit crossover is cheaper, but ofcoarse it's not going to be optimum. I'll see if it can work out with a center horizontal MTM first, maybe tweak it a bit. If it sounds good, I'll buy 6 more for my new living room setup. Cost wise, the polk will probally still be better. However, I'll have some time come end of spring semester. So it'll be a good time killer.
            • savage25xtreme
              • 305
              you should avoid the pre-built cross overs like they are the plague. If you have the tools and time build something easy BAMTM or TriTrix or Nat P's..... if not get some Polks.... they will certainly make noise that may even be satisfying to you :B
              Gavin
              BAMTM Build
                Agreed.
                The Polks will likely sound better than random drivers and a prebuilt crossover.
                • mintos
                  • Apr 2009
                  • 62
                  What's wrong with that pre-built crossover? It's a standard 2nd order LR filter. All the components look like quality and the 2500hz crossover point fits the speakers well. I just have to pick up some resistors for a L-Pad.
                  Otherwise the bill of materials look like this
                  004-4 Yes Dayton DNR-4.0 4 Ohm 10W Precision Audio Grade Resistor
                  $0.98 $5.88
                  027-422 Yes Dayton DMPC-4.7 4.7uF 250V Polypropylene Capacitor
                  $2.41 $2.41
                  027-430 Yes Dayton DMPC-12 12uF 250V Polypropylene Capacitor
                  $4.57 $4.57
                  027-436 Yes Dayton DMPC-20 20uF 250V Polypropylene Capacitor
                  $6.09 $6.09
                  027-440 Yes Dayton DMPC-30 30uF 250V Polypropylene Capacitor
                  $8.95 $8.95
                  027-450 Yes Dayton DFFC-0.01 0.01uF 400V By-Pass Capacitor
                  $0.74 $1.48
                  027-427 Yes Dayton DMPC-6.2 6.2uF 250V Polypropylene Capacitor
                  $2.66 $2.66
                  $28.57 $28.57
                  255-206 Yes Jantzen 0.15mH 18 AWG Air Core Inductor
                  $3.63 $3.63
                  $24.70 $49.40
                  255-104 Yes Jantzen 1.5mH 15 AWG P-Core Inductor
                  $9.66 $9.66
                  Subtotal: $123.30
                  Plus another $25 or so for the cabinets.
                    There are so many posts here that explain why a pre-built crossover is not optimum that I'm not going to answer that.
                    • savage25xtreme
                      • 305
                      the prebuilt crossovers do not take into account ANY of the following: baffle diffraction, step, mechanical and electrical properties of the drivers to mention a few. they are simply an electronic filter. what if you 2 drivers don't play to the same level? no notch filters or level adjusting resistors? take a look at the crossovers in the Missions Accomplished section of this forum. you will notice that few if any of them are as simple as the pre-builts, there is a reason. the crossover network is a function of drivers and the enclosure, not the other way around. :W
                      Do what you wish though and be sure to post the results :T
                      Gavin
                      BAMTM Build
                      • mintos
                        • Apr 2009
                        • 62
                        I bought the Polks, let me post some pics when they arrive ... jk
                        Actually, I get what everyone is saying. I don't see the pre-built XO as the end. But 2500hz is a good point for those two speakers. The response chart shows both speakers are very flat around it, and good enough for 2nd order. Thus, I'll use the prebuilt as a starting point. Once I finish modeling the cabinet, I'll build it and then modify the pre-built XO depending on the sound from the speakers in the cabinet.
                        • Undefinition
                          • 577
                          :rofl:
                          Well, now that I think about it, your choice of drivers are excellent for a first design. They're both very easy to work with. The TB W5-704 has a very flat Frequency Response, and the Vifa DX25 has a very low Fs. Plus, the fact that you're running an MTM--assuming the woofers are parallel--means that you will suffer very little, if any, baffle step loss.
                          You could probably do such a design with a 1st order XO. I used the W5-704D with a 1st order XO in the Aethers, and lots of people seem to like those.
                          • Mudjock
                            • 98
                            You may be new to this, so I can understand your position that a textbook filter should work if the drivers are similar in sensitivity. The first speaker I built started out that way (I eventually learned enough to fix it).
                            You might find the following thread helpful in showing how far off a textbook filter can be from what you really want.
                            Given the frequency and impedance data for the W5-704D and DX25, it would be possible to give a reasonable simulation of what type of response curve a textbook LR2 filter would lead to - if you require further evidence that the off-the-shelf crossover is not the way to go.
                            I have heard the Tritrix and used the w5-704D (with a different tweeter than Augerpro) and based on that, I am confident that either design will easily surpass the sound quality of the Polks or any speaker that most people would consider "affordable".
                            Keep an open mind, but don't let your brain fall out...
                            https://sites.google.com/view/sehlin...solutions/home
                              Paul,
                              I was in a bad mood earlier. I should have pointed him to your FAQ's. Surprised you didn't.
                              • Undefinition
                                • 577
                                Paul,
                                Naw, don't feel bad. You just gave me a good belly laugh is all.
                                • mintos
                                  • Apr 2009
                                  • 62
                                  Does all textbook 2nd order crossovers need to have Tweeters in reversed polarity? (Seems like it, just want to double check)
                                    Yes, the phase shift on a second-order crossover is 180 degrees(reversed polarity).
                                    • Undefinition
                                      • 577
                                      Textbook, yes. However, very few speaker designs use textbook filters. When it comes to how a given filter and its component values affects the acoustic phase of a driver, you really need simulation software. There is a chance you could be 180 out of phase... or somewhere in-between. :E
                                      My Girl From Ipanema design is basically a straight-up 2nd order (though still not textbook values), and as you can see the drivers are both wired positive, and the acoustic phase is extremely tight through the crossover region
                                      • mintos
                                        • Apr 2009
                                        • 62
                                        which software can I use for this?
                                        • Undefinition
                                          • 577
                                          Good question. And the comforting answer is that it will cost you zero dollars to get started.
                                          Some folks like Speaker Workshop (very versatile, but can get quirky to operate at times)
                                          Other folks (myself included) enjoy Jeff Bagby's Passive Crossover Designer
                                          ... you will also want to grab Jeff's Response Modeler while you're there. This can help with doing box and baffle diffraction models, plus extracting minimum phase.
                                          The rest of the gaps are filled in well by Roman
                                          To get a handle on the the stuff, you can trace the FR and impedance graphs (using SPL trace) for your drivers, and plug that into the software above. Yes, there are some steps in the middle I didn't mention, but there is just no substitute for just getting your hands dirty and trying things out. (there's even a button for "load textbook filter" if you want that to get you started!)
                                          • mj1856
                                            Polk Speaker Comparison
                                            by mj1856
                                            Hi guys,
                                            Thanks for all the help so far in my thread about power ratings. I thought I should break up the speaker discussion into it's own thread.
                                            So, I thought I was settled on which speakers to get, so I went down to Circuit City to give them a good listen before searching...
                                            19 August 2004, 15:27 Thursday
                                          • zacjones
                                            Speaker placement with a 120" screen
                                            by zacjones
                                            We're setting up the old theater in a new house, and are running into some speaker placement issues.
                                            If your screen is too big, forcing you to place your mains wider than optimal for your viewing distance, is placing all three L/C/R speakers below the screen an option?
                                            02 April 2011, 13:34 Saturday
                                          • Flipx99
                                            Polk Audio Monitor Series
                                            by Flipx99
                                            I am very new to HT. I already have a Pioneer Elite ex-500 series DVD player and receiver, and a Samsung Slimfit 30" TV.
                                            My room is 20 * 26, but the listening area is closer to 12 * 12. (It a finished upstairs, has barn roof-like angles). I am considering purchasing a speaker package...
                                            28 November 2006, 19:28 Tuesday
                                            Modula MTM's to look like Monitor Audio's
                                            by dar47
                                            My buddy David at work was considering buying some Monitor Audio floor standers and later building the rest of the 5.1 setup. I said he should maybe forgo the Audio Monitors and build the Mudula MTM's in a tower format as his room is rather small. I offered to build his cabs as his was stuck in the...
                                            11 January 2012, 14:57 Wednesday
                                          • stevecuss
                                            Newbie help with MTM and Morel Tweeter project please
                                            by stevecuss
                                            I bought someone's left over MTM project today and would greatly appreciate any guidance with my first DIY speaker build.
                                            I bought 3/4" MDF cabinets (17.5" tall, 8" wide and 14.5" deep) with pre-routed MTM layout on the front and a rear port hole...
                                            08 July 2008, 23:26 Tuesday
