I had a guy I know do the crossover for the statements center for me. Here is a picture of the finished crossover.... wondering if it looks right? I will get some more pictures of it later.
Finished crossover for statements center.
The construction looks fine. From the pic I can't tell if its wired correctly or not, but judging from the apparent forethought he put into it, I'd guess it is likely wired OK as well.
C- Bottom
Originally posted by MT SpeakersIt is interesting that you do not seen to know if it is OK.
Why would you ask someone you have confidence in, to build something and then insult the person by asking a bunch of lurkers if it is built ok?.- Bottom
If you consider the designer of the network in question "a bunch of lurkers," why are you here? An MD has quite a bit more experience in the medical field than I do, but if he makes a diagnosis on something as serious as a crossover, I'm getting a second opinion. And he better not be insulted.- Bottom
Anymore of this nonsense and people are going to lose their posting privileges...
Well the guy that built the crossover is darn good. I tried using heat shrink tubing and just burnt up the first crossover I made. So on the crossovers you see, I did not use any heat shrink tubing. So when I saw your cross over I thought there was a lot of good stuff here.- Bottom
Originally posted by 06'goatYeah, see i know nothing about crossovers.
Give this article a read:
Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
Verifying that the actual crossover is wired as intended is fairly easy. Just take it a section at a time, and holler if you have any questions...
C- Bottom
CDIY - once you start down that (dark) path, forever will it dominate your destiny!- Bottom
