3 way Usher or 3.5
  • markmelheim
    • Jan 2009
    3 way Usher or 3.5
    Greetings gentlemen,
    I need some help, I've built Troels Acapella Seas, And Dennis Murphy's Usher 2 ways. I know nothing about crossover design or taking measurements to modifiy the circuit. I do have all the drivers listed below and do need help to build. I want advice so I can get these to work in a 1 box solution, possibly separate chambers for mid-lo1(7") & mid-lo2(8") & 10"woofer.
    10' front or side firing and then w8"w7" t
    Any help is truly appreciatted, Thanks Mark
    I do have a crossover design for the 7" & 8" and Usher tweeter but no box size, Its from the web or AudioXpress or a pub Joe D'Appolito wrote. Sealed or Ported ???
    I have
    4- 7inch 8945A usher
    2 -8inch 8955A usher
    2 - 25w8565-01 Scanspeak
    Tweets
    2 - 9950-20 usher
    The crossover is below but i have no idead the box size, I would love to put the drivers to use with the Scanspeak 10"
    Usher 8945A 7"
    +o--Cap----Inductor----*----------*-----------------resistor--------o +
    .54uf 1.5mh/#18 | .1.3ohm10w
    Inductor Cap
    3.6mh/#18 14uf
    | | | o--------------*-------------*------------------------------------o -
    Usher 9950 Tweeter
    +o---Cap 8.2uf ------*------Cap 15uf-----resistor 1.5ohm /5w-*-----o+
    Inductor .43mh/#18 Resistor 15ohm/5w
    -o------------------*-----------------------------------------*-----o –
    Usher 8955A 8"
    +o---------Inductor 8mh-----*---------Inductor 3.6mh-------o +
    Cap 175uf
    - o------------------------- *-------------------------------o -
  • gitarretyp
    Usher Klippel Test
    by gitarretyp
    I've seen mentioned a few times here and elsewhere that the Usher 8945A was recently measured by Klippel to have 10mm of xmax, and in the same test set, the Seas Excel W18EX had ~3mm of xmax. Does anyone have the actual reference for this information?
    10 March 2007, 19:36 Saturday
  • augerpro
    Symmetro: a proof-of-concept
    by augerpro
    Thought I'd share a project Derek (deschu) and myself are working on. This started with my experience that despite the technical shortcomings of the MTM, I often really like their sound, better than an identical TM at times. I'm not the only one and I think the assumption is that there is reduced sound...
    22 January 2017, 19:19 Sunday
  • Jed
    Usher 8955a, Scan Speak 12M, and Peerless HDS 3-way project
    by Jed
    This project doesn't have a name yet, but the title pretty much sums up which drivers I'm using. I mocked up a simulation using measurements found online and using the FRD tools. Things look promising. My goal is to have a true 2nd order design, and while the HDS tweeter doesn't have that much output...
    31 December 2006, 12:35 Sunday
  • Amphiprion
    12 New Drivers Measured at Zaph Audio
    by Amphiprion
    Just an FYI.
    ETA: The Usher 8945A looks like the new low distortion champ at $110, better than anything else. There are several cheapies that did quite well (MCM and the like). The new GR was average.
    10 December 2006, 09:34 Sunday
  • NateTTU
    New 3 Way: HDS + 8948A + 8955A
    by NateTTU
    Hey guys,
    I seem to hang out more often at the PE forums, but lately I haven't been getting much input. Theres a little higher amount of traffic over there and I know another 3 way topic probably doesn't sound too interesting. Just thought I would post this in another forum to see if...
    29 June 2011, 20:26 Wednesday
