Equation relating t/s parameters to sensitivity vs frequency
  • thadman
    • Jan 2007
    • 248
    What is the equation relating t/s parameters to sensitivity vs frequency?
  • Amphiprion
    • 886
    That will get you eta naught. Then 112.2 + 10 log(eta naught) = efficiency. If I've remembered the formula correctly it will give you efficiency at 1w/1m. The LDSG list has the equations in it if you have the text on hand (I don't at the moment).
    The gist of it is that you will gain the most sensitivity by raising Fs via lowering cone mass, all else being equal.
    • thadman
      • Jan 2007
      • 248
      What specific factors affect Vas and Qes as mass affects Fs and over what bandwidth does this equation apply?
      • thadman
        • Jan 2007
        • 248
        I found what I was looking for, for those interested:
        Fs= 1 / (2*Pi*sqrt(Cms*Mms))
        Qes= (2*Pi*Fs*Mms*Re)/Bl^2
        Vas= 1000*P*(C^2)*(Sd^2)*Cms, where P=density of air (1.184 kg/m3 at 25°C) and C=speed of sound of air (346.1 m/s at 25°C)
