Please evaluate my Tritrix Tower design
The curves you've created remind me of the work of a local sculptor, David Hostetler.
http://www.davidhostetler.com/
Maybe it's because his work is all over campus here that I see the resemblance.
I like the idea.
Bill SchneiderMy audio projects:
http://www.afterness.com/audio- Bottom
Should consider massing load the bottom or bolt them to a plinth.
Further development... with center channel and bases for the towers...
I decided that the towers were going to definitely be too top-heavy, even with a sand-filled chamber in the bottom, so I added a base to them... the extra slabs of 1" mdf in the base (shown in the 3rd picture in black) are simply to add weight... the upper most slab (shown wood-colored) is going to be doweled to the side walls of the tower for strength.... a big 'ol lag bolt through the middle of these slabs will fix the tower to the base.
The center channel is as large as it is in order to work well with the TV stand (the TV is going to sit directly on top of it)... the center channel has internal walls to create a sealed 7 liter enclosure, to match the towers...
Not sure what color I'm going to paint them yet... gotta consult with my better half on that one.
That isn't a further development. Further development would be cutting some wood.- Bottom
Originally posted by ---k---That isn't a further development. Further development would be cutting some wood.- Bottom
The plinth needs to be much larger too offset the mass at the top of the speaker. 3 little pieces of MDF aren't going to do anything toward mass loading the bottom
Originally posted by ThomasWThe plinth needs to be much larger too offset the mass at the top of the speaker. 3 little pieces of MDF aren't going to do anything toward mass loading the bottom- Bottom
You might want to make up several size plinths then experiment regarding the smallest one that will prevent tipping. I think you'll be surprised at how big it actually needs to be to effectively stabilize the structure
Originally posted by ThomasWYou might want to make up several size plinths then experiment regarding the smallest one that will prevent tipping. I think you'll be surprised at how big it actually needs to be to effectively stabilize the structure
My concern at the moment is whether or not I'm going to be happy with the MTM center... I've read that this format is less than ideal, but that the Tritrix is better for centers than most MTM's since the drivers are so close together...
The tritrix is the only center channel design I've found that is 8 ohms... my Yamaha HTR 5930 isn't rated for 4 ohms... I've heard that it might be ok at 4 ohms, but no one seems to know for certain... definitely don't want to do all this work and then blow my receiver.- Bottom
It's a vented Tritrix with an internal volume of 22.3 liters... drivers, port, crossover, and foam lining volumes have not been subtracted from this volume... Dayton shielded 5.25" classics, Dayton silky tweeter... crossover not shown, yes it will be inside the enclosure (haven't decided where yet).
Depth and height of the enclosure have obviously been changed from Curt's original design, but the baffle width has not been changed... all walls are 3/4" mdf, except for the side walls which are 1"
The curved back walls will be an adventure in kerfing and bondo
They might be a bit top heavy... I'm prepared to make a wider base if need be.
Lining is PE 1/2" open cell foam... think that's thick enough?
Let me know if you have any concerns with this... bear in mind that I'm not after absolute perfection here, but if there's anything glaring please let me know.
Many thanks for your help with this...
Originally posted by Dougie085I'd like to know how the heck your going to curve a piece of wood like that- Bottom
I agree with Mazeroth. I recently heard some Modula designs at the Dayton DIY and they were very good sounding for the money.
I also don't understand why you would spend all that time on curving a part of the speaker you'll never see (the back).
Jed- Bottom
You've got yourself a nice 150 Hz. organ pipe there, and the foam will absorb just about nothing at that frequency.- Bottom
I believe that he is going for the Tritrix because it is 8 ohm and an easy load on his existing receiver.
Got a source for the 1" MDF? It will be harder than you think to find.- Bottom
Just a quick comment. If you make the back piece the full width of the enclosure it will be much easier to build. In your drawing you have it between the sides. If you cut the sides first, then put the back over it, you'll have something to form the curve with. Easiest way to do that curve is to get 1/8" or 1/4" masonite. Bends very easily. Do one layer at a time and then laminate each layer until you get to the correct thickness.
John- Bottom
Originally posted by MazerothIf you're going to go through all the effort to build these why not up the ante and build something with better SQ? Maybe cjd's RS MTM or, if you want to go bigger, the Natalie P or Modula?
2. Want something 8 ohm- Bottom
Originally posted by John_E_JanowitzJust a quick comment. If you make the back piece the full width of the enclosure it will be much easier to build. In your drawing you have it between the sides. If you cut the sides first, then put the back over it, you'll have something to form the curve with. Easiest way to do that curve is to get 1/8" or 1/4" masonite. Bends very easily. Do one layer at a time and then laminate each layer until you get to the correct thickness.
John- Bottom
Jed
...also, if the back were just a flat wall, and I was still planning on having the curved sides, I'd have to make the whole enclosure much deeper in order to maintain the volume.- Bottom
Originally posted by Deward HastingsYou've got yourself a nice 150 Hz. organ pipe there, and the foam will absorb just about nothing at that frequency.- Bottom
Originally posted by lunchmoneyFor the love of the challenge... I'm a designer by profession, and I really get into this sort of thing... this will be in my portfolio with pictures from different angles.
Maybe you could find a way to curve the front too.- Bottom
1/2" foam won't absorb anything other than treble and a higher midrange frequencies.
Did you model the tuning of this box with a loudspeaker design program?
Aesthetics is one thing and loudspeaker design is usually something completely different.
There's a reason Curt's designs for this are deep as opposed to shallow.
Originally posted by lunchmoneyDo you think this design has significant issues?- Bottom
Originally posted by ThomasWThere's a reason Curt's designs for this are deep as opposed to shallow.- Bottom
Originally posted by Deward HastingsI think that if you don't stuff that pipe with absorbant it will honk like a wing of Canada Geese, with severe ripples every 150 Hz. all the way up to crossover. And that if you do stuff it enough to stop that you will lose much of the benefit of the port tuning. If you want to make it a transmission line you need to treat it as such from the beginning, understanding that that's a whole different design.- Bottom
Originally posted by djgMake the top of your design the sealed version. You could still curve the back and maintain much the same shape and volume of the original box. Continue the back to the floor. It would be a little deeper than what you have now.
Oh well, easy enough to make it sealed... Curt's 7 liter version is about this shallow... is that too shallow? Should I base it on the 10 liter version instead?- Bottom
Originally posted by lunchmoneyIs it because of the shallow depth that you see this problem?- Bottom
Originally posted by Deward HastingsNo, it is because it is long . . . a pipe . . . with a natural resonance related to the length. The reason we keep boxes box shaped is to keep all dimensions relatively small, and the standing wave resonances high enough to be easily damped (or not excited at all in the case of subwoofers) without interfering with the lower frequency mass/volume resonance of the port. Working around the resonances of a pipe makes for very difficult enclosure design. The only choices that are likely to work are highly damped sealed (almost IB) and transmission line (wihch will take careful attention to design, measurement and stuffing detail.
If I make it similar in depth to Curt's 7-liter design, it wouldn't need to change much at all... do you think that's deep enough? or should I base it on the 10-liter design?- Bottom
Originally posted by ThomasWDid you model the tuning of this box with a loudspeaker design program?- Bottom
Originally posted by lunchmoneyfoam lining volumes have not been subtracted from this volume...
As others are pointing out, you'll want much thicker behind the drivers. On the sides won't be so important. Top and bottom could get important.
If he mounts the port up higher, and stuffs the whole bottom of the speaker with Acustic Stuff or Fibre Glass, would that work to get rid of the resonance?- Bottom
Originally posted by ---k---You don't subtract out this volume. The foam actually works to increase the volume seen by the drivers.
Yeah, I wouldn't have any problem having the port be higher.
Would that work?- Bottom
Ok, how about this then?... 9 liters sealed... lining not shown.
Internal height and width is exactly the same as Curt's sealed designs... obviously I've gotten a bit creative with the depth... but according to Curt anything between 7 and 15 liters is acceptable... the 7 liter design is certainly shallower than this.
Think this will sound ok? Being used in conjunction with a sub...
Originally posted by ---k---If he mounts the port up higher, and stuffs the whole bottom of the speaker with Acustic Stuff or Fibre Glass, would that work to get rid of the resonance?- Bottom
Originally posted by lunchmoneyOk, how about this then?... 9 liters sealed... lining not shown.
Form follows function, and all that . . .- Bottom
Originally posted by Deward HastingsDon't "line", stuff. Pick you box size not by "looks" but to give a Q of .7 and an F3 at your desired crossover frequency, or reasonably close. Any box modeler will "do the numbers" for you . . . WinISP Pro or whatever.
Ok, stuffed it is... Curt recommends "100% fill" for the sealed enclosures... what exactly does this mean?
Thanks for your help!- Bottom
Originally posted by lunchmoneyOk, supposedly the Q of a 10 liter box for this design is .707... so I guess I'll make it 10 liters.
""give or take, more or less" is what "100% fill" means, too. I had a Dahlquist DQ1W that had the box so full of foam and fiberglass and "stuff" that looked like the scrap box from a carpet store that when you unscrewed the driver it popped up three inches from the baffle from the pressure. I think most people mean somewhere between a half pound and a pound per cubic foot of fiberglass or poly batting, which will probably fill the box enough that you'll want a layer of foam behind the driver to keep it from migrating and touching the cone. You'll have to ask Curt what it means to him.
I like to see more by weight, but I use the higher density "rigid" rockwool, so even a couple pounds per cubic foot doesn't necessarily completely fill the box. I don't use foam at all, since fiberglass and rockwool are much more effective. And I don't "line" the box because air motion is greater, and thus the damping material more effective, away from the walls.- Bottom
No, it is because it is long . . . a pipe . . . with a natural resonance related to the length.- Bottom
Originally posted by Dennis HIt's not like nobody ever built a good sounding tower before.- Bottom
