I'd like to build John's ZD5 but don't have the time or inclination to build the cabinets. In fact I would have Madisound build the crossovers and have a local shop do the router work. The problem of course is that the PE .5 cubic foot cabinets are 8.5 inches wide which he specifically warns against. Recommendations would be helpful. Thanks, Tony
Zaph ZD5 in PE Cabinet?
Well it seems you've already answered your question. I suppose you have two options. Pay someone to build the cabinets for you to spec (that local shop you speak of) or build the SR71 since you can get the cabinets and baffles ready-made for it. Of course the ZD5 is in another league though...- Bottom
I know one guy who was happy with these in a 7.5 cu ft PE MTM enclosure, vented with the port on the front below the woofer, tuned to 30 Hz. It's an 8" wide enclosure, close enough to not make too much of a difference. I'd do sealed first, and if that's not enough bass for you, convert to vented. And you might as well make it one of the sexy curved cabinets too.
Crossover assembly is difficult for this system. I somewhat regret publishing something so complicated. If someone builds the crossovers for you, I'd ask for an impedance test with the drivers hooked up to check everything out.- Bottom
Zd5
Will take your advice for having the crossover built. And, bite the bullet and build the cabinets myself. I want to stay as close to your design as possible. Just don't have much time. Thanks for taking the time to respond John. - Tony- Bottom
