The PA130 MTM - 102dB with 8 watts, under $90/pair
  • max_andrews
    • 23
    Bored at work, fun! Would be great paired with a sonic impact t-amp. I might offer these up as a kit if I have the time...
    Last edited by theSven; 28 April 2024, 11:01 Sunday. Reason: Update image location
  • Xander
    • Dec 2007
    • 132
    looks fun, what are the box dimensions?
      That minimum phase modeling? Does it include box response or something? Something in the data looks weird.
      • Gir
        • 309
        Looks good! Are these simulated or actual measurements? They've got some good low end extension for smaller speakers. Is it ported?
        -Tyler
          They're on the drawing.
          They're sims or as we prefer to call them vaporware...
          • max_andrews
            • 23
            As Tom mentioned, these are simulated from PE's data. I'll be building them soon and I think one guy on the PE board happedne to have the parts already so he was going to give them a shot this weekend. They are indeed ported, 2" diameter by 6.5" long. If you make the box 12" deep you can get a bit more extension with a 2.5"x 6" vent.
            The use an EBS style rolloff, so the F3 is high but the extension is decent.
            • max_andrews
              • 23
              It's what FRD extracted after I merged the box response, could that be what you're seeing?
                Did you extract miminum phase and properly set z-axis offset? If you didn't do the phase step you're going to get very different results in reality.
                • Jed
                  • 3621
                  I agree with CJD, the phase doesn't look right and you are getting a dip at 5kish as the result. Don't let that discourage you though. This is design that looks like it has a lot of budget appeal.
                  • max_andrews
                    • 23
                    Minimum phase was extracted after the last step for each driver, after baffle modeling, bass modeling, etc. Acoustic offset is set at 1" for the tweeter. I think the 5khz phase issue is due to the woofer's breakup at that point, but a notch might be rather pointless because the effects are so small and will completely disappear just a few degrees off axis, and given the budget another $7 worth of inductors would drive me nuts I'll do a bit more modeling tomorrow and see if a notch can be done on the cheap. Is that the only place where the phase looks funky?
                    • max_andrews
                      • 23
                      updated crossover
                      Thanks for the advice everyone! The problem was solved by very slightly lowering the xo point for the tweeter (to about 3050 from 3200), as well as adding a .025mh inductor (tiny!) in series with the shunt capacitor in the woofer's circuit. This significantly attenuates the breakup node and improves phase. +/- 2.5dB from 100hz-20khz, not bad IMO
                      In terms of added cost, if you use NPE caps for everything (the last one used a dayton 5% poly for the first tweeter cap), it should be exactly the same at about $95/pair including terminal cups, drivers, XO parts, and port tubes.
                      Last edited by theSven; 28 April 2024, 11:03 Sunday. Reason: Remove broken image link
                        Thanks max. It's hard to tell and it looked like it may have been a standard glitch in SW from files without phase data, or with PE's phase data. So I asked to be sure.
