Calling Nat P Tower Builders
  • SilverJS
    • 28
    My Nat P's are currently in sealed enclosures modeled on the .75 cubic foot PE enclosures, but I'm thinking of putting them in towers. I understand about 50 liters net, as the archive thread mentions, is ideal, and with a 3" port; I've got a 3" flared port kit on the way from PE. So :
    1. The thread mentions 11" long of a port with a non-flared port. How long should I make mine?
    2. Am I correct in my understanding that placing the port at the bottom, front or back makes no real difference?
    3. The discussion surrounding the tweeter's height in the Statements thread has sort of put the bug in my ear...what should I aim to be at ear-level with the tower Nat P's, then? Tweeter or top woofer?
    Cheers!
    JSB
    Color me confused, you have this setup.
    Given the standard port tuning (around 30Hz), there's nothing gained by converting to a minitower since you're running subs.
    Usually tweeters are approx ear level, some people prefer slightly above or below depending on the seating position and the relationship between the mains and the center.
    Last edited by theSven; 17 August 2023, 20:16 Thursday. Reason: Update image location
    • SilverJS
      • 28
      Correct, that is my setup. However, I am actually not that happy about how I built the enclosure and want to revisit them. I would also like the option of simply going full-range, no sub for some music styles. Plus I would prefer the look of towers.
      Would I lose midrange by going to towers?
        FWIW, I built a tower Nat P for a friend as an ML-TL using Martin King's spreadsheets. IIRC, internal dimensions were the same or very close to the PE cabinets, just 46" tall. Rear port near the bottom, 3" ID x 6" long. That gets response down into the low 30s with some room gain. Sounds nice, although somewhat restricted in how loud it can get due to displacement of the RS180s.
        Personally, if you like the sound better without your subs, I'd work on integrating/improving your subs. My friend went this way just to delay needing a sub. Even though theoretically you don't have much below 40 Hz in popular music (everyone seems to forget about 5 string basses...) I find the sound much more satisfying with a full range system.
        You can always build the tower with a partition where it the current bottom is and keep everything the same.
