DIY -- but not speaker related!
  • zzzz
    • 78
    Hi everyone,
    What I am trying to do is have an amp turn on once the receiver turns on/sends audio to my speakers. My receiver has a 12v trigger, the amps I am looking at do not, nor "auto-on" sensing.
    If I can figure this out then the Behringer a-500 may be an option to power the mains.
    Many thanks for any suggestions!
    • 3791
      • 10931
      Many of the prosound companies make trigger based sequencers.
      I use a Furman PS-PRO II SMP 3-Step Sequencer to turn on 3 power amps. They make ones for less demanding tasks as well.
      • zzzz
        • 78
        Thanks Dennis and Thomas. Wow those Furman's (is that politically correct?) are expen$ive.
        In the meanwhile I did some research and found AudioSource amps that are (a) relatively inexpensive and (b) have an auto-on feature.
        Anyone know anything about the quality of AudioSource amps? I have read a few positive reviews on the web.
          • 3223
          Originally posted by zzzz
          Hi everyone,
          Here is an option if you just want to turn on other components.
          Also Parasound used to make a product called the Scamp that did the same thing. You can find them used on Audiogon.
          HTH
          • zzzz
            • 78
            HTH
            Thanks again Jim. I'll have to look into that option.
              • 10931
              That's their most expensive unit, which is why I posted "They make ones for less demanding tasks as well." Those are less expensive and can be found on their website.....
              • zzzz
                • 78
                http://www.furmansound.com/
                Gotcha.
                Even their cheapo stuff is a tad pricey (for me). Probably just me
                Thanks for the link!
                • ahaik
                  • Feb 2007
                  • 233
                  Z,
                  I had the same problem with my older parasound amps, I'm using this , you can find open box ones for less on Ebay.
                  Asi.
