Disclaimer: I can't see this one going 20+pages like the "Project Overkill" thread. End of Disclaimer
Quick notes.
-I have built Cjd and Brian Bunges 3-ways and added 2 12" dayton subs on topof each cabinet.
-I recently cut off the sub cabinets, sold the subs and am wanting to build 1 if not 2 subs with the 18" IXL's(easy on the canadian buyer).
-Sub will consist of 1 driver front firing(max 2 cabinets) or 2 opposing drivers(max 1 cabinet)
-room is roughly 17 x 22 x 7.5 feet
-power will be supplied by 1 Behringer ep2500
-also have a active crossover if needed cx2310
Project idea to start. Opinions and insults :B encouraged
Over on avs there is a thread with a gentleman named Dan building a ported sub with the above mentioned driver.
Dimensions are as follows:
24 3/4" H&D by 49" L
403 Liters
6" port 37.5" long
Tuning 11.5Hz
I am using these numbers as just a guide to help me with the design. I don't think I want to build just a regular box, but I don't want this to get out of hand work-wise or money-wise. I plan to buy wood, insulation, and some gasket material. I have everything else.
Here are the t/s par. for the Mach 5 and the web page.
le = 6.09
Fs = 17.7 Hz
Re = 3.4 Ohms
Qes = 0.39
Qms = 5.59
Qts = 0.37
Mms = 434.3 grams
Rms = 8.69 kg/s
Cms = 0.184 mm/N
VAS = 274.1 litres
Sd = 1029.2 cm2
Xmax = 22 mm
Cone Diameter = 36.2 cm
Power Handling: 800 watts RMS
Sensitivity: 89db (2.83 volts)
Impedance: 4 Ohm Nominal (SVC)
Outside Diameter: 46.2cm (18 3/16")
Mounting Diameter: 42.4cm (16 11/16")
Depth: 24.8cm (9 3/4")
Recommended Box Sizes
Sealed: 130 litres (4.6 cu. ft.)
Ported: 200 litres (7 cu. ft.) 19Hz tuning
EBS: 350 litres (12.4 cu. ft.) 15Hz tuning
This is my first try at Unibox. Could use a look over to check things by the pros.
Images not available
Btw the wattage I used(800watts) is not right. So I guess we could nix the excursion graph.
I know this is a lot to look at for the first post, but I thought I would try and figure a few things out first.
Mike
P.S. it's 11:30 am and I got back from work a few hours ago. So I am off to bed. I will check back in a few hours.
Quick notes.
403 Liters
6" port 37.5" long
Tuning 11.5Hz
le = 6.09
Fs = 17.7 Hz
Re = 3.4 Ohms
Qes = 0.39
Qms = 5.59
Qts = 0.37
Mms = 434.3 grams
Rms = 8.69 kg/s
Cms = 0.184 mm/N
VAS = 274.1 litres
Sd = 1029.2 cm2
Xmax = 22 mm
Mike
