This might be a dumb question but what size drill bit should be used for pilot holes? Should it be the same diameter as the screw going into the hole? And how deep should the pilot hole be, same deep as screw? Finally does the same logic apply whether its a normal screw or lag screw?
General Drilling Question
Originally posted by PezThis might be a dumb question but what size drill bit should be used for pilot holes? Should it be the same diameter as the screw going into the hole? And how deep should the pilot hole be, same deep as screw? Finally does the same logic apply whether its a normal screw or lag screw?
See if this helps:
Steve- Bottom
In addition to the chart Seeker mentioned you might find this to be of some help.
Some info on screws
Originally posted by PezThis might be a dumb question but what size drill bit should be used for pilot holes? Should it be the same diameter as the screw going into the hole? And how deep should the pilot hole be, same deep as screw? Finally does the same logic apply whether its a normal screw or lag screw?- Bottom
More info please.
MikeCall me "MIKE"
Dual sealed 18" Mach-5 ixl 18.4 subs- Bottom
Originally posted by kingpinAll depends on what material you are screwing in to and the purpose of the screw.
More info please.
Mike- Bottom
