Originally posted by cujet
Many people read my little article on the subject and simplify it a bit too much. You can't say lower Xmax drivers always sound better, you have to look at the whole picture if you are comparing drivers of different design. About all you could say for sure is that if two woofers shared the same design but one had shorter Xmax, the one with shorter Xmax would have lower distortion up to the point where it's Xmax is exceeded.
With woofer design, as the excursion requirement for a single woofer becomes higher, the overall design becomes harder to engineer, more expensive to manufacture, and susceptible to some specific design shortcuts that may result in higher distortion. Just be careful with your generalizations and realize that sometimes, a better route to take might be an array of well-designed lower Xmax woofers vs a single high Xmax woofer of lesser design.
I've actually got a stack of RS270's in their boxes sitting around waiting for me to do a multiple woofer project. A couple of those per side will satisfy my output requirements and do it with very low distortion. I was actually thinking of 4 per side but I'm a couple RS270's short of that.
