Need a fine weight scale
  • frascati
    How to print a pdf template to scale?
    by frascati
    I just redrew it using the dimensions there. But for the future. How is it possible to print a pdf to exact scale? I asked at a couple of "computing" forums and was told again and again that you must print, measure, resize, print, measure, resize, etc, to get it right. That seems...
    25 February 2010, 12:16 Thursday
  • GregoriusM
    Weight of receiver a significant factor?
    by GregoriusM
    Hi.
    If my Rotel 1056 doesn't come back fixed (which I hope it does), I have chose the following in my price range to consider (Rotel included for comparison).
    I was quite surprised to see quite a difference in weight.
    NAD T753 $1500 CAD 90 w/ch 6.1 ch -...
    25 May 2005, 22:36 Wednesday
  • Grzywa
    B&W 683 and ASW610 MODS (Marble base plates - plinth, SubTrap, add weight on top)
    by Grzywa
    Hi !
    I have few ideas on tuning my speaker setup. I would like to get your opinion on them. Do you think it makes sense? Do you think it may help or not? If some ideas seem to be good for you but there is something you would like to add? This kind of feedback I'm counting on.
    1....
    09 April 2013, 00:13 Tuesday
  • ZiggyB
    RSX1067 Weight Question....
    by ZiggyB
    Silly question really - what's the real weight of the 1067? Online says it's 54 lbs, downloaded manual says 44.97 lbs. Before I buy, trying to figure out if my Bello stand can take the weight with all the other components, or if I need to bring out the concrete reinforcements
    Many...
    22 July 2004, 10:22 Thursday
  • parodielin
    Natalie P MTM Weight
    by parodielin
    I am recommending Natalie P MTM to a friend. He will be using the PE 1.0 cabinets but would like to know how much the overall system would weight once it's built.
    Does anyone remember how much a Natalie MTM in PE 1.0 cabinet weight?
    04 January 2011, 15:07 Tuesday
