Originally posted by Jed
New 3-way coming up.
Here's an example of the test waves I'm talking about, distortion is fairly audible using this test wave. The picture is analysis on four of the test waves (ideal input, not output).
I made a series of these test waves in separate files and uploaded them to my site. You don't have to use them, but I thought this might give you some level of audible distortion testing for the drivers you have that I am interested in.
Archive not available
It should sound like a clean pop, like popping the top off of a jar.Last edited by theSven; 23 September 2023, 08:45 Saturday. Reason: Remove broken image and archive link- Bottom
Just ask Mr. Ohm....- Bottom
Will be very interested to see your progress.
~Jon
Should have a system ready for measurement this weekend. I'm glad I made my baffles removeable on my last speaker design. I'm still waiting for the 25W so it looks like the Aura will be the first 10" I try.- Bottom
C79 free air impedance
Aurasound NS10 513 free air impedance
Usher 8955a 60L closed box impedance
Usher 8948a free air impedance
Visaton MHT12 impedance
Image not available- Bottom
Originally posted by Dennis HWow, no impedance hump at Fs for the C79?- Bottom
Originally posted by JedNope... I thought it was odd too, but I took several measurements that would indicate my results are accurate. We'll see what the impedance looks like in a sealed box this weekend.- Bottom
update- drivers in box
Breaking in the drivers as I type. These drivers are in another league of the own. More to come.
The Scan Speak 25W will be here Friday, so that will have to wait.- Bottom
aperiodic vents
Originally posted by JedSo what do you predict will be the winning combination Jim, 3-way with Aura or Scan Speak?
:B
Has anyone tried Scan Speaks' aperiodic vents. They are supposed to lower the box resonance, improve power handling, & tighten the bass.
I'm going to try'em in my speaker project. My help your 25W with power handling. You'd need two - ($9.00/ea.) Mandisound. If you go with the 25W.
John
John unk:
My Website (hyperacusis, tinnitus, my story)- Bottom
Jed, just missed your last post. Your speaker sounds impressive.
Images not available
If, anyone has experience with these aperiodic vents, I'd like to know.
I'm new, I hope these picts get posted!! 8OJohn unk:
Originally posted by JohnloudbJed, just missed your last post. Your speaker sounds impressive.
Yeah, from what I'm hearing with the Aura so far I'm not sure the Scans will surpass them--- but I have a lot of work on measuring and optimizing the crossover network. The Aura will be ported, and the Scans either sealed or with the aperiodic vents as you suggested. Both in 60L.
By the way, welcome to the forum. You'll find the people here very knowledgable to say the least.
Let us know what projects you have planned!- Bottom
Rd 50
Originally posted by JedYeah, from what I'm hearing with the Aura so far I'm not sure the Scans will surpass them--- but I have a lot of work on measuring and optimizing the crossover network. The Aura will be ported, and the Scans either sealed or with the aperiodic vents as you suggested. Both in 60L.
Thanks, Jed. Well, here is what I'm working on. It's a 2 way B-G RD50 design. Front baffle is Maple.
I had almost decided on the HiVi D8G (an 8" with 9mm of Xmax)
Then I saw the ScanSpeak Revelators on sale for $115. The box could be 2" to 3" shorter with same f3 of about 54Hz. I'm using an active crossover (300Hz).
Not Sure - what you think?
DG8:
Image not availableJohn unk:
Originally posted by JohnloudbI had almost decided on the HiVi D8G (an 8" with 9mm of Xmax)
DG8:
7-8" woofers
Ok, I'll nix the D8G. 7" Scan Speak looks good. Any other favorite 7" to 8" woofers. I'm new to speaker building ... I've designed and built electronics, mostly.John unk:
Originally posted by JohnloudbOk, I'll nix the D8G. 7" Scan Speak looks good. Any other favorite 7" to 8" woofers. I'm new to speaker building ... I've designed and built electronics, mostly.
Check out zaphaudio.com for driver tests. For a 7" up to 300hz, Usher is worth considering.- Bottom
VERY bad news.
It appears my Accuton C79s are defective. The impedance is messed up/ doesn't match the manufacturers plots, and the FR drops off like a cliff below 1K with a 12db peak at 2k and it just gets worse from there. I cross referenced to other drives I had on hand like the tweeters and woofers, and I got perfectly acceptable results. I just emailed the vender where I got these so hopefully things will get straightened out. :M
Seize the Day
Originally posted by JedIt appears my Accuton C79s are defective. The impedance is messed up/ doesn't match the manufacturers plots, and the FR drops off like a cliff below 1K with a 12db peak at 2k and it just gets worse from there. I cross referenced to other drives I had on hand like the tweeters and woofers, and I got perfectly acceptable results. I just emailed the vender where I got these so hopefully things will get straightened out. :M
Adversity is the spice of life - savor these moments! :B
zaphaudio.com really helped. They liked the 7" Scan Speak Revelator the best and it will work great with my RD50s. So, I bought 4.John unk:
What size is your subenclosure?- Bottom
Originally posted by JohnloudbAdversity is the spice of life - savor these moments! :B
NOTHING is easy so you might as well try to enjoy the challenge.
Congrats on the Scan Speaks, you can't go wrong with those revelators.
Jed- Bottom
Accuton's are going back for replacement tomorrow. Very odd that both would have such poor FR. There is no visable damage to the cone at all.
I keep thinking that it is something that I'm doing wrong, but every other driver specs out pretty close to the manufacturers specs.
Jed- Bottom
Gone
Originally posted by JedAccuton's are going back for replacement tomorrow. Very odd that both would have such poor FR. There is no visable damage to the cone at all.
Jed
"Hello John -
I regret to inform you we sold-out of the 18S sale drivers prior to your order.
There is a small chance that some will become available, so I will contact you within the next couple days if that happens.
Best regards -
Adam"
Don't pay with PayPal when it matters. Credit card orders are filled first, at Madisound.
I found a new love, though. It's design for a sealed box with f3 of 48Hz in a 20 L enclosure. ($160.00)
The Scan-speak 18W/8535 7" woofer -
TECHNICAL DATA:
Sensitivity 2.83V/1M 86.5dB
Free air resonance Fs 26 Hz
DC resistance 5.8 ohm
V.C. inductance 0.3 mH
Power 70W
Effective cone area 145 cm2
V.C. diameter 38 mm
V.C. height 15 mm
Air gap height 5 mm
Lin. & max. excursion Ā±5 / Ā±10 mm
Force factor BL Product 5.7 Tm
Moving mass incl. air 15.5 g
Net weight 2.5 kg
Vas 72 liters
Qms 2.50
Qes 0.45
Qts 0.38
Outside diameter: 177mm
Cut out: 158mm
Depth: 70mm
25.4mm = 1" = 2.54cm
It has a very low resonance peak. Lower than the 18s/3531G Revelators. My question is - wouldn't this be a better driver for a sealed enclosure with crossover freq of 300Hz? The freq response is smooth, almost identical to Revelators.John unk:
Jed
What you get should look something vaguely similar to this, of course, with variation due to your baffle size and shape.
No one's going to confuse this with a subwoofer, but that's not the point-
Was your vendor an individual or one of the internet resellers?
I've never had issues with any Accuton's from Madisound, though I did get a bad pair of SS9800, they seemed to have been "fried" by someone. Previously.
~Jonthe AudioWorx
Are the VC's locked? That would account for the strange measurements, possibly.
~Jon
I bought them from an internet reseller (not madisound- they are all out of Accuton C79s and C90s). He will test my units to confirm that they are defective. I talked to him for awhile to prove I knew what I was doing etc. I'm not about to play around with the cones to see if the VCs are locked, but that seems like a possibility, especially if these were a return of some sort and sold as new. I doubt that but you never know. The drivers definitely had no signs of use before I got them. So hopefully I'll have some new C79s that work within the next 2 weeks.- Bottom
It has a very low resonance peak. Lower than the 18s/3531G Revelators. My question is - wouldn't this be a better driver for a sealed enclosure with crossover freq of 300Hz? The freq response is smooth, almost identical to Revelators.- Bottom
Two Scan 21W/8555-00
Originally posted by JedThat's a nice driver, yes. But, as I start to work with larger diameter woofers I can't imagine ever going back to a tiny 7" driver for bass duties. :W
(P.S. in fairness to Madisound they have my favorite drivers and provide excellent service.)John unk:
Hi Jed, looks like a nice project you have going here. A couple of years ago I purchased a pair of C79s from an online vendor for a project that did not work out. When I got them I gave them a close visual inspection and they looked fine. I dusted them off on the weekend to get ready for your project and found a small hole in the spider close to the voicecoil. It's the same on both drivers. Looks to be a stain around the edge of the hole darkish brown in color. From sitting so long (I turned them upside down every so often), could the ferrofluid have leaked on to the sider and "burned" a hole?
Cheers, Wayne- Bottom
Originally posted by WayneOHi Jed, looks like a nice project you have going here. A couple of years ago I purchased a pair of C79s from an online vendor for a project that did not work out. When I got them I gave them a close visual inspection and they looked fine. I dusted them off on the weekend to get ready for your project and found a small hole in the spider close to the voicecoil. It's the same on both drivers. Looks to be a stain around the edge of the hole darkish brown in color. From sitting so long (I turned them upside down every so often), could the ferrofluid have leaked on to the sider and "burned" a hole?
Cheers, Wayne
Jed- Bottom
Originally posted by JohnloudbI Hear Ya. My problem has been box size. Two Scan 21W/8555-00 might fit. What Qtc would you shoot for in a closed box? 0.7, 0.8 or higher?
I wouldn't go over .6-.7 Qtc to tell you the truth. Take a look at Usher 8955a over at partsexpress if you are considering the Scanspeak. You'll save a lot of money and equal performance. The Kevlar 8" Usher looks interesting as well. 2 of those per side would be interesting. I've used the Usher 8955a sealed and thought it was excellent.- Bottom
Usher
Originally posted by JedI wouldn't go over .6-.7 Qtc to tell you the truth. Take a look at Usher 8955a over at partsexpress if you are considering the Scanspeak. You'll save a lot of money and equal performance. The Kevlar 8" Usher looks interesting as well. 2 of those per side would be interesting. I've used the Usher 8955a sealed and thought it was excellent.
For a Qtc = 0.7 only the kevlar/carbon, Usher 81374 will work, with f3 of 60Hz. I'm really liking it though, so is my wallet.John unk:
Originally posted by JohnloudbFor a Qtc = 0.7 only the kevlar/carbon, Usher 81374 will work, with f3 of 60Hz. I'm really liking it though, so is my wallet.
As for more developments with my 3-ways, I've decided to go ahead and buy SoundEasy. By the time I have working drivers, I might as well try to learn some new software. Plus I want to take distortion measurements of my own.
Edit: Soundeasy is backordered- Bottom
TrueRTA
Originally posted by JedShould offer you some nice tight bass. Check out the low distortion specs too.
John unk:
Jed did you check if e-speakers has SE in stock?- Bottom
8 inch woofers
I'm a novice, but the distorion numbers look great. Lower than many preamps I've read about!
Let me know when you get those 25W Scans.John unk:
Originally posted by JedLSPcad is on its way to me as I type! Looking forward to learning a new speaker design software.
Jed
The only way right now I can imagine LSPCAD being better would be if "the EDGE" were built in and usuable in the design flow. That, and a tracing utility like FRD tools.
~Jonthe AudioWorx
