My A500 amp arrived today, so I finally hooked my sub up. The CX2310 is used in "stereo 2-way + sub" mode - upper half going to the mid+tweet panel, lower half going to the woofer boxes, and now the sub out as well, which goes to a BFD and then the A500.
The mid/woofer XO works, I've been using that all these days, obviously. My question is about the summed sub output, and the XO in the middle of the unit. As far as I can tell, it's low-passing the subwoofer output, but it's not high-passing the woofers. So I essentially have a "bring the sub in under the mains" scenario. Is this how this is supposed to work? I'd thought it would high-pass the woofers as well, so I'd end up with a bandpass on the woofers with the limits set by the 2 XOs.
If this is how it works, then I guess I'll see how blending the sub goes, but part of my reason for getting a sub is so I could EQ it, and i don't really want my woofers getting the low frequencies, because that'll be exciting room modes that I won't be able to control.
There's also a 25Hz cut button on both inputs - does that cut the woofer output, or will it cut the sub as well? I guess I can answer this question by putting in a test tones CD. It doesn't sound like it's cutting the sub out, so maybe this is the closest I can come to removing the low bass from the woofers.
Anyway, I know some people here use this unit, so if anyone's tried the "stereo 2-way + sub" mode, please shed some light on this
Saurav
Saurav
