Out of curiousity, has anyone attempted a relatively traditional three way with the RS 10", 5", and tweeter? I know the crossover would probably cost a penny, but it would be interesting. Certainly the sensitivity wouldn't be as good as WWMMT or WWMTM, but the form factor and SAF could be appealing.
3 Way using RS270, 150, 28A ???
Tags: None
Meh.There is no WWMMT, just WWMT
I'm not sure the box size for a sealed RS270 is smaller than for a pair of RS225's. Very close. Don't consider porting the 270, it gets huge.
So.
Um..
Why?
CdiVine Sound - my DIY speaker designs at diVine Audio- Bottom
Well, one "why" of the matter might be impedence. One 8 ohm RS270 would help keep the impedence up as compared to a pair of 8 ohm RS225's wired in parallel. I had a look at your three way RS tower, for example, and the impedence seems to run about 3 ohms for the most part. That is in no way a complaint against the design, but there are applications where a bit higher impedence is desirable.- Bottom
If you have gear at the level these speakers run, the impedance won't be an issue.
Sure, it could be done. I don't think you'll get a size advantage for the loss in sensitivity no matter how you spin things. There may even be someone out there that has. If impedance were the biggest worry, I'd switch to the 4ohm RS225's and a Seas tweeter in a variant on the TMWW towers.
In fact, I'm eyeballing a TMW for use in my HT (near-wall/on-wall if not corner loaded) but 4ohm 225 woof, probably dome mid and tweeter.
Lots of stuff out there. I think Roman B has a design that's along the lines you've described, but not those specific drivers.
As you may have surmised, I would be interested in them for HT, as I have a HT receiver that happily does 4 ohms, but I would hate to push at 2.5-3 ohms.
I suspected you would bring up the sensitivity issue, as I had already envisioned that as a sticking point to the design.
As for your sugestion, when you say use the 4 ohm RS225, do you mean wire two in series?
Thank you for the input.- Bottom
Well, I have two thoughts on the 4ohm 225. One use is, of course, two in series.
The other is to use a single 225 in a design that does not require baffle step, which is how my own cramped room is likely to run when it comes to HT speakers. So I would go with a single 225 in that case, still run ~90dB+ sensitivity. 4ohm still.
Only the big WWMTM towers should really give your receiver an issue. If you are looking at those for your HT, you're still gonna go with a receiver?! :P The WWMT's should be just fine. I suspect the WWMTM's would be, for that matter. Not much SAF on average, though there are a few of us lucky enough...
And, hopefully I'm not coming across too grumpy - it's become evident as the day has worn on that I am exceedingly grumpy. No idea why.
