2 Mach 5 MAW-15 800 watts and no place to go
  • court109
    • Nov 2006
    • 10
    I have 2 Mach5 audio MAW-15 on the way
    Use this area to place widgets or custom HTML for your visitors. This is a custom widget displaying a summary of a chosen page. It would automatically get the excerpt of that page and place it here (or wherever you place the widget).
    Power Handling: 500 Watts
    SPL (2.83v/1m): 90.2 db
    Impedence: 4 + 4 Ohm
    T/S parameters (with coils wired in series):
    Fs = 26 Hz
    Re = 8 Ohms
    Qt = 0.32
    Qes = 0.35
    Qms = 3.35
    Mms = 232.8 grams
    Rms = 11.42 kg/s
    Cms = 0.000159 m/N
    Vas = 129 liters
    Sd= 756.3 cm2
    Xmax = 13 mm
    Diameter = 31.1 cm
    Dimensions
    Outside Diameter: 39.4cm (15 1/2")
    Mounting Diameter: 35.6cm (14")
    Depth: 16.8cm (6 5/8")
    And I have a Tapco J-800 power amp
    This website is for sale! tapcoworld.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, tapcoworld.com has it all. We hope you find what you are searching for!
    I would really appreciate some advice on what kind of cabinet to put them. My room is a dedicated hometheater 18x24, IB is not an option, I don't mind sonotubes, but I would rather build a single large box.
    I was thinking 350-400l tuned to 17.5hz. I have been playing with WinISD, but to be honest I don't understand half of the graphs.
    This forum is amazing and I can't wait to get started on my first DIY project.
    Hadn't seen these yet. Let me look at them...
      Okay here's the deal, a properly made 350-400L box is going to weigh a TON. Oops sorry I don't know the proper metric terminology for this ....:wink:
      Anyway think 250lbs or more...
      • court109
        • Nov 2006
        • 10
        the terminology would be metric ton (1000 kg or 2200lbs)
        My speakers each way 100lbs and so does my power amp so 250lbs woundn't be the end of the world, I'm still building the hometheater so I can sort of disguise it.
        Whats involved with a properly made box ?
        I was thinking something like 20" w x 48" h x 36"d I still have to work out the exact dimensions. It would have two ports side by side horizontal and then the subs mounted vertically.
        Like so ...
        00
        O
        O
        Your AS-15 project is kind of my inspiration, I just wanted to double the ports and drivers.
        Can I get by with .75" MDF sides and rear and 1.5" mdf baffle?
        • jonathanb3478
          • 440
          If you wanted to do that, I would think you should use very extensive bracing. As in there was no area smaller than ~ 9"X12" that didn't have a brace of some kind running through it. Personally, I would brace like that and still do 1.5" thick enclosure walls on all 6 sides. That is just me, though.
          Maybe others can chime in on what they think would be reasonable.
          -Vernon Sanders Law
            jonathan has it pegged.
            If you used real baltic birch ply with extensive window bracing you could get away with .75" walls.
            The Mach 5 woofers have a relatively modest Xmax. So two of them is equal to the output of the single driver in the AS-15.
            You don't need or want two ports. That doubles the port length and that's not necessary
            • court109
              • Nov 2006
              • 10
              I'm starting to understand why sono-subs are so popular.
              Would two co-located sonotube subs work as well a two drivers in a single box?
              Is 200l per driver tuned to 17.5 with 400w per driver a good design choice?
              • jonathanb3478
                • 440
                Seems like a good design choice to me.
                What size port are you planing to use? I would go with a 6"er, personally.
                If you prefer the dual sonosub route, go that way. You can co-locate them with two different tubes, just as with one box.
                -Vernon Sanders Law
                • mrogowski
                  • 55
                  Hi Court,
                  As the others said, going Sono with such a volume would be the suggested route. Its light, cheap and strong. You can bang a sub together in a day verses having to wait for panels to glue-dry.
                  Separate Sono's would be a better choice, but it all depends on what you can live with. Having two 16" - 18" tubes standing around may be a bit imposing.
                  Throwing numbers around, if it were me, I'd go with a 180l box and tune it to 20Hz - 6" port 26" long. Throw a couple of circular braces in the tube and line it with R12 or R20 fibreglass. Your about 6db below the knee at 16Hz which is pretty good. Look into getting yourself an EQ to compensate for any irregularities if you don't already have one. They should pound pretty good for you...
                  If you do plan to stick with wood, the dimensions you mentioned are interesting - 36" deep? Can your room take a 3 foot deep cabinet? Just wondering...
                  Best,
                  Mark
                  Where no sound has gone before
                  • court109
                    • Nov 2006
                    • 10
                    I really like the look of a box with a nice exotic veneer, but it's hard to ignore the practicality of the sonotube design.
                    So unless you guys see something wrong I'm going to go with two 20" 200l sonotube subs, tuned to 17.5hz with 6" ports and a 3/4" round over. I'll wire the VC in series and each sub in parallel to give me 800 watts at 4 ohms
                    Thanks for your help I'll post pictures when the subs arrive
                    • mrogowski
                      • 55
                      There's nothing saying you can't veneer a Sonotube...
                      • Jack Gilvey
                        • Aug 2001
                        • 510
                        Throw a couple of circular braces in the tube...
                        Do they make a measurable difference? Most don't bother (not that that means anything substantive, of course).
                        • mrogowski
                          • 55
                          Well, through my extensive and very thorough testing methodologies (read: the 'hand on tube' test) I did notice less flexing of the tube at high volumes around the area of the braces. I even considered running three cross braces running lengthwise between each circular brace when building my Baker's Dozen, but I got lazy.
                          Best,
                          Mark
                          • court109
                            • Nov 2006
                            • 10
                            Veneering a sonotube interesting, has it been done before? A burled walnut sontube, I like it.
                            I'm confused on the EQ thing, it seems more popular with sealed subs (I guess I have a lot of reading to do)
                            Is it mandatory, or something I can mess with later? Is there a Coles Notes version of the differences between the 3 Behringer units people use, DSP1124P, FBQ2496 and DEQ1024.
                              Most sonotubes don't have a very smooth outer surface so you'd be looking at a lot of filling and sanding to keep the spiral pattern from printing through the veneer. An (expensive) alternative is the 5/16" plywood cylinders from Tape-ease.
                                Start here and then see the links at the bottom of the page
                                Forget about trying to veneer the tube. Make a lightweight rectangular wooden frame that slips over the tube. Cover it with thin plywood.
                                • court109
                                  • Nov 2006
                                  • 10
                                  Thanks Thomas
                                  That's a very interesting overview. I didn't realize how cheap the DSP1124 and the FBQ2496 were; even in Canada. The DEQ2496 looks really cool to bad it costs more than my two subs and amp put together.
                                  As for beautifying the sonotubes I think I'll just add solid hard wood caps, my main speakers are PSB Stratus Golds with an Oak finish maybe I try and match those. Then cover the tube with a material sock.
                                    If you don't need to store different program settings for music vs ht, the FBQ is easier to program and has more flexible filters settings.
                                    If you want separate settings for music vs ht, the DSP1124P is the one to get.
                                    • jkrueger
                                      • 78
                                      Ton?
                                      Proper Canadian spelling is "Tonne"
                                        Okay thanks.
                                        Hey how about sending me down a few dozen oysters? I haven't been to Vancouver Island since 2001 and I'm going through withdrawal..... :B
                                        • mrogowski
                                          • 55
                                          I dunno. I think veneering would be a good easy choice. I would have looked into veneer myself but it wouldn't have fit our decor.
                                          There's always MakTak...
                                          Best,
                                          Mark
                                          • jkrueger
                                            • 78
                                            Oysters
                                            Thomas - How many oysters do you think that it would take to make up a Kilogram?
                                            • Bent
                                              • Sep 2003
                                              • 1570
                                              It doesn't look good to mention being in vancouver and then suffering any kid of withdrawal. :lol: :lol:
                                                Ahh, let's see, would it depend on their size?......
                                                Possibly not.... :B
                                                During the off season the island is one of our favorite places to vacation.... :T
                                                • Bent
                                                  • Sep 2003
                                                  • 1570
                                                  Yup, everybody knows a kilogram of oysters is heavier than a kilogram of shrimp... Otherwise they wouldn't be called shrimp, would they. ops:
                                                  And I agree, Vancouver is a beautiful city.
                                                  :B
                                                  Last edited by theSven; 15 July 2023, 11:12 Saturday. Reason: Update image location
                                                    This where we usually stay......
                                                    Last edited by theSven; 15 July 2023, 11:15 Saturday. Reason: Remove broken image link
                                                    • jkrueger
                                                      • 78
                                                      Off Season
                                                      Thomas, I am not a fan of oysters, but if you let me know when you will be through my fair city, I would gladly treat you to a pint of our finest local ale. There is a thriving beer scene in Victoria. :beer:
                                                      Jonathan
                                                      • court109
                                                        • Nov 2006
                                                        • 10
                                                        Subs arrived today, very well packed, quick delivery, even included bolts to mount the drivers. They look very impressive to me (I don't have a lot of experience though)
                                                        MAW15
                                                        • court109
                                                          • Nov 2006
                                                          • 10
                                                          Hey Jonathan;
                                                          I haven't been posting on forums very long but I believe that is what they call HiJacking
                                                          Any sign of the tsunami in Vancouver
                                                          • jkrueger
                                                            • 78
                                                            Oops
                                                            Unintentional Highjack. I will mind my manners. :W
                                                              Hey Jonathan;
                                                              Abandon your thread and all kinds of things happen when you're not looking... :W
                                                              • court109
        • Nov 2006
        • 10
        That's too funny
        Well my wife went into preterm labour yesterday, which stopped around midnight, (thank god) and my two year old's baby sitter got sick this morning. I am going to have a hard time keeping up with this thread, let alone actually build the subs in the near future.
        Never fear though, I'll find sometime, to bug you guys with novice questions.
        Sorry to hear about the complications, hope all goes well.
        We'll keep your thread warm while you're away... :T
        • court109
        • Nov 2006
        • 10
        Mach 5 Question for Mark
        Hey Mark,
        Have you ever considered selling power amps, and EQ's from your website? It seems unfair that our American friends can by a Behringer EP2500 for 299 US$ and we are stuck paying 500 $cdn. Same goes for the DSP1124 and the FBQ2496.
        When ever a power amp comes up on ebay in Canada there is always a lot of interest, which would lead me to believe that there would be a lot of interest on fairly priced online canadian retailer.
