Tite bond 3 recommendation
  • dynamowhum
    • 260
    This may be old hat to some or you may have something better; but, I really like using titebond 3. It cost a couple more dollars than the other two but it really works for me. The slower setup time means I can nudge my stuff around to get it just right before the glue sets up. With bigger panels and 1 set of arms this really helps. I think the bonding strength is the same so no loss. Cheers.
  • PMazz
    • May 2001
    • 861
    And it's waterproof vs water resistant (Titebond II) in case you drop your speakers overboard.
    Pete
    Birth of a Media Center
      • 5204
      Yeah, Tightbond II is usually recommended here. But for my latest project, I've been using III and like it. It seems to spread around easier and easier to work with. I actually got mine at Harbor Freight, and it was cheaper than II is at Lowes.
      • dynamowhum
        • 260
        Pmazz you know I go overboard for my speakers. LOL
