For all who've heard critical Q subs and IB setups...what are some differences between typical IB installations and low Q sealed subs, in regards to sound signature? Why would a ELQ sub (<.4 Qtc.) not sound similar to an IB installation, given extreme cabinet bracing?
When does a sealed sub mimic IB?
...our brains and nervous systems constitute a belief-generating machine, a system that evolved to assure not truth, logic, and reason, but survival...
2x15" TC Sounds .45Q sealed
M. Boutte HT
3x15" @ 10 HzTags: None- Bottom
Dunno. I think its the fact that in a "true IB" the owner knows that there is no restoring force on the sub other than what the coil sees. That's just my take on it.
Personally, I would love to have a quadruple stack of your TC3000s in that Q5 box. With a EP2500 strapped to each coil. Cause, why the phuck not?
Ah....eight TC-3000s.....
*Homer Simpson drool*
Actually, I think 4 or more 18" LMS-5400s would pretty much tap me out! :E- Bottom
It's not just the "Q", it's the lack of the interaction with the box that gives an IB the edge with regard to SQ.
Originally posted by Scott SimonianDunno. I think its the fact that in a "true IB" the owner knows that there is no restoring force on the sub other than what the coil sees. That's just my take on it.
Actually, I think 4 or more 18" LMS-5400s would pretty much tap me out! :E...our brains and nervous systems constitute a belief-generating machine, a system that evolved to assure not truth, logic, and reason, but survival...
M. Boutte HT
3x15" @ 10 Hz- Bottom
Assuming the box is totally rigid and not radiating, one difference is air spring distortion. According to SL's worksheet:
(Air spring distortion %) = 140 * (driver 1-way Vd) / (box volume)
Another is the non-linearities due to heating etc. that drivers experience when you pump a lot of power into them. If you have a small box with a lot of EQ on the low end, it's going to take a lot of power down low.- Bottom
Originally posted by kramskoiFor all who've heard critical Q subs and IB setups...what are some differences between typical IB installations and low Q sealed subs, in regards to sound signature? Why would a ELQ sub (<.4 Qtc.) not sound similar to an IB installation, given extreme cabinet bracing?
If the impedance is higher at a given frequency, less current flows through the coil, and heat in a motor can only come from I^2*R where R = Rdc.
If you take a look at a few preferred IB solutions you might notice some trends related to this. :roll:Mark Seaton
"Make no little plans; they have no magic to stir men's blood..." - Daniel H. Burnham- Bottom
