ive been sitting on the AA ava15 since the closeout pricing... wondering if there are any plans floating around or prefered voliume and tuning for HT use
does anyone have plans for AA avalanch 15"?
I'd shoot for ~300 effective liters with a 6" diameter port that is between 27-30" long, fed with ~600 watts.- Bottom
Gotta do what it takes :T A large and low tuned ported enclosure has numerous benefits when paired with a quality driver. wackii just built this same sub last week:
Hi all, I've just purchased an ava 15 used. I'm planning to build a sonotube for it. I need some pointers from the experts here. Below is the AVA 15 t/s. Fs 15.7 Hz Qms 3.5 Qes .334 Qts .305 Vas 300.6 L Re 3.2 ohms Znom* 4 ohms Xmax 27 mm Sd 749 cm2 Mms 269 g Vd 4.04 L Pnom 800 watts Le 2.4 mH Cutout 14- Bottom
Peter, check out my thread as Steve mentioned below. It's a 300L sonotube with 6"dia and 28" long port powered by QSC RMX850 (830W 4ohms bridged). I've just completed the measurements. Bass are incredible. I say...GO FOR IT... You won't be disappointed. It's huge like you said. I kinda like it big ( like to intimidate my friends). Good luck.
Al,- Bottom
